light comming on when braking ??? advice
as above when ever i press my foot down on my brake the light comes on under my speedo i checked the fluid theres plenty there??? any ideas?>
The light is duel purpose to show the parking brake being on or low brake fluid as you have checked the fluid it's not that.
Check the 3 pin connector on top of the brake fluid resoviour isnt loose as IIRC with this removed the light will illuminate.
MK2 does not have brake pad warning.
Martin
Martin
abs light is on constantly but always has been but now its the red handbrake light wenever i hit the brake peddle ive checked fluid but cant get my wheels off as my locking nut snapped to check pads ect
MK2 does not have brake pad warning as I say!
Martin
Sounds like you have a really serious fault with your abs if the yellow light is staying on. The sensor on top of the brake fluid reservor could be faulty.
for fook sake its one thing after another so whats the best way to go about sorting all this out then would you say, sorry im not clue'd up on all this, ive checked fluid thats fine ill check the sensor on top of the reservoir tomorow check thats all connected then if no joy what lol ???
Karl 3dr
102
Oct 14, 2016 08:17 PM
track.focus'd
Aug 12, 2015 05:53 PM
