PC Watercooling Gear
neeeeeeeeooowmmmm
Not sure how much interest this will get, but I want it gone as it was for a pc I was building, that I can no longer build.
1x Swiftech MCR220 Radiator
1x Swiftech MCR320 Radiator
1x Swiftech MCRES micro reservoir
3 and a bit metres of black hose, 1/2 inch ID I believe (cut in metre lengths)
8x 7/16th fittings, nikel coated brass (I think, they're brass for sure though)
8x Jubilee clips to suit fittings
2x lcd temperature displays, these have been spliced into in-line temperature sensors.
Everything is new and not been used, rads were flushed when I bought them, which was a while ago, so will need to be flushed again! The MCR220 has a small amount of damage from storage, mainly the paint has come off, still works as usual. Damage can be seen in pictures.
The lot
MCR220
MCR320
MCRES
Hose
Fitting, Jubilee clips, temp. Displays
All for £100+postage ono.
Will split only if the Radiators go first!
PM me if interested
The lot
MCR220
MCR320
MCRES
Hose
PM me if interested
The Youth.
Sep 30, 2015 09:59 PM
