focus st170 lambda sensor problems
Old Oct 19, 2010 | 09:01 AM
diamond's Avatar
diamond
Default focus st170 lambda sensor problems
hi all......
i have recently took my st170 for its mot....all it failed on was the emissions.
it has been plugged in, and found an issue with the lambda sensors.
this is fine, although i have sourced the 02 sensors from;
GSF
CES
EURO CAR PARTS
FORD MAIN DEALER
who have ALL supplied the wrong parts, even though its the original exhaust fitted and they have cross referenced the reg and even the part number off the faulty 02 sensor.
the problem is that the ones on my car are ANGLED at the bottom, and all other ones are STRAIGHT !!!!!!!
can anyone help please???
thanks
jim
Old Oct 19, 2010 | 07:00 PM
Does it need to be angled ?, has your one been bent at some time ?
Old Oct 19, 2010 | 07:19 PM
stevos's Avatar
stevos
May jusy be a revised version of the old one happens quite alot although i can't be sure in your case but seems unlikely they would all be showing the wrong part.
Old Oct 19, 2010 | 07:27 PM
phil_focus's Avatar
phil_focus
as said probably a revision, may be your oe ones are actually broken.
are they a different make to the oe ones?
post some pics up of old vs new.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
