cosworth breathers..?
Old Oct 17, 2010 | 08:16 PM
gibbo frst's Avatar
gibbo frst
Default cosworth breathers..?
hi..
does anyone know of a breather suitable for a cossie thats larger than the baily style one or even a more square shape that could fit where the battery goes on a saff. im sure the baily one ive got is fine but now the battery is in the boot the breather looks lost.. im just looking at filling the space a bit really.. ive seen some at shows like what im after but guess they could have been custom made...
thanks for any help..
Old Oct 17, 2010 | 08:24 PM
Mark RS's Avatar
Mark RS
collins do them,my mate has one it may be for sale pm if intrested
Old Oct 17, 2010 | 08:28 PM
gibbo frst's Avatar
gibbo frst
do you have any pics at all mate..?
Old Oct 18, 2010 | 06:52 AM
DIY matey, if you have a welder ?, can be done a large type like this for under £20.
I can put you onto someone who can make one to your design if you want, doesn't cost the earth but is pukka.
Old Oct 18, 2010 | 06:29 PM
gibbo frst's Avatar
gibbo frst
thanks.. ive got a welder but really want something to look good in the bay..
also i wouldnt have a clue how to design my own other than id like the same size fittings as my baily one but a bigger box to fit where the battery was..
ive seen ones at shows ect but guess they were custom made too..
Old Oct 18, 2010 | 06:41 PM
The man I could recommend was making a one off fuel tank today, he would no doubt fold the metal on his 8 foot folder so you get nice neat edges etc, but there's a lot of satisfaction diy, maybe spray afterwards, but I understand if you want a pro looking one.
There's seriously nothing technical about the design a box pipe and ideally media inside, which bailey don't have, would make a much more effective breather, the important pipe is the breather itself, and the media that stops the oil laden fumes escaping, scrub buds are good for this.
Old Oct 18, 2010 | 07:55 PM
gibbo frst's Avatar
gibbo frst
something like these..?
Old Oct 18, 2010 | 08:00 PM
Mark Shead's Avatar
Mark Shead
Spec R would make something that suits your needs.
Mark
Old Oct 19, 2010 | 12:55 PM
Paul_RS's Avatar
Paul_RS
Thats the one i'd part with cheap, two -10 and one -12 inlet. -12 spout has been slightly cross threaded, but i can supply it with a replacement weld on fitting, or the existing one may be able to be fixed?
Old Oct 19, 2010 | 06:33 PM
Cossie_ray's Avatar
Cossie_ray
Loads of different styles on ebay.
http://shop.ebay.co.uk/i.html?_nkw=o....c0.m270.l1313
Old Oct 19, 2010 | 07:16 PM
gibbo frst's Avatar
gibbo frst
thanks for that i have looked at most on ebay but as im not really too sure what i need .. think once my voice comes back ill ring spec-r and see what they can do.. i like the look of the one on mad rods saff although it might be overkill on my car it does look really good and obviously works..
Old Oct 19, 2010 | 07:48 PM
BRAMMER's Avatar
BRAMMER
I bought this off Justin i think it's a spec r system but with aero quip fittings plus and extra one fitted to the tank
Old Oct 19, 2010 | 08:04 PM
gibbo frst's Avatar
gibbo frst
i had one of those style ones but sold it on because i dont want the big tank sitting by the airfilter.. .. im in no rush as got lots to do on the car still...
Old Oct 19, 2010 | 08:11 PM
Cossie_ray's Avatar
Cossie_ray
Nice set up that Chris. I have a similar setup waiting to be fitted.
Your setup will look good with these AN-12 Hoses
Cossie_ray's Avatar
Cossie_ray
http://cgi.ebay.co.uk/12-AN12-Nylon-...item255bfb706a
Old Oct 19, 2010 | 08:12 PM
STUCOS's Avatar
STUCOS
Have a new style spec r one on my saff,and goes were the battery used to live,same as on rod tarry,s car
cheeRS stu
Old Oct 20, 2010 | 07:32 AM
What part of the word breather do spec r and similar not understand, where's the breathing it needs, it's pathetic, no doubt another empty vessel by someone(spec r) who doesn't have a clue about oil vapour, not that it is technical!!
Old Oct 20, 2010 | 10:34 AM
gibbo frst's Avatar
gibbo frst
Are the spec r ones on the shelf to go the same as rods or do you have to specify it and have it made
Old Oct 20, 2010 | 10:25 PM
STUCOS's Avatar
STUCOS
Spec r ones are made to order,but dont be in a hurry lol
cheeRS stu
Old Oct 20, 2010 | 10:30 PM
Mark Shead's Avatar
Mark Shead
You havent had a look in my desgin breather Spec R makes as in Rods version, It is a breather seperator unlike the normal style open pot as quite a bit of work went in to that to make it work on the topspeed runs.
Mark
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
