which fuel tank for my 1989 s2 mfi
Old Oct 16, 2010 | 09:02 AM
stevealien's Avatar
stevealien
10 Year Member
Default which fuel tank for my 1989 s2 mfi
Hi Chaps,need a little help please.
Need to replace my fuel tank on my 90 spec 1989 mfi s2 esc turbo.
removed old tank and it has the slim type senderwith a white float.
ordered another tank,its arrived but its got a bigger hole on top with a different sender and a black float.
do you know what the difference is and if the replacement will work?
have i got the wrong tank on at the moment? should it be the big sender one?
is the slim sender one for efi?
if its compatible gotta spend hours trying to clean it out cos the prat who sent it to me didnt bung the holes up,sent it in a box of loose polystarine packing,and its all got inside the tank,been melted by the old remains of fuel and its like glue everywhere.
so basically,need to know if it will defo work before i assign my day to sortin it.
thanks my lovely rs brothers
Old Oct 16, 2010 | 10:08 AM
rsmark86's Avatar
rsmark86
ive got a spare mfi s2 tank and sender sat in the garage and its painted gloss black aswel ... if you need it otherwise its going in the bin
Old Oct 16, 2010 | 10:41 AM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
rs mark if he's not interested in the tank i might be depending of postage price mate cheers
Old Oct 16, 2010 | 10:43 AM
rsmark86's Avatar
rsmark86
to be honest i havent got the time to sort out postage but if you can sort a courier then i will have it by the front door wrapped up ready to go....
Old Oct 16, 2010 | 10:50 AM
stevealien's Avatar
stevealien
10 Year Member
Hi rsmark.
Appreciate the offer of a tank buddy.
Do you know if the big hole and small hole types are both compatible?
If yours is mfi i guess it will work on my mfi?
And i in milton keynes so you not too far from me are you??
thanks fella
Old Oct 16, 2010 | 10:53 AM
rsmark86's Avatar
rsmark86
im not sure mate but i took it off a mates 250bhp s2 and worked fine so im sure will fit yours no problem and it was a 1988 model so im sure will have no problems im thinking the tank you got must have been an efi one
Old Oct 16, 2010 | 10:56 AM
stevealien's Avatar
stevealien
10 Year Member
how far you from mk mate
Old Oct 16, 2010 | 10:57 AM
rsmark86's Avatar
rsmark86
not sure mate post code is rg12 7qb
Old Oct 16, 2010 | 11:01 AM
stevealien's Avatar
stevealien
10 Year Member
ooooooh.thats a 140 mile round trip for me.
I`ll leave it for now fella.
Really apprreciate the offer mate,you a good chap
Old Oct 16, 2010 | 11:04 AM
rsmark86's Avatar
rsmark86
thats cool its there if you need it
Old Oct 16, 2010 | 11:16 AM
stevealien's Avatar
stevealien
10 Year Member
thank you
Old Oct 16, 2010 | 03:51 PM
stevealien's Avatar
stevealien
10 Year Member
somebody must know the answer to this.come on guys.
pleeeaasseeee
Old Oct 16, 2010 | 04:16 PM
phil_rs's Avatar
phil_rs
yam yammer
The one on your car is the correct tank with the smaller sender so you will need to replace it with the same if you want your fuel gauge to work correctly
Old Oct 17, 2010 | 04:46 PM
stevealien's Avatar
stevealien
10 Year Member
I have connected the fuel sender and manually played with it and it's very accurate on the guage. Can't see how it would be any diff on the car. Guess I'll have to try it
Old Oct 18, 2010 | 06:36 AM
Marc LJX's Avatar
Marc LJX
IIRC all S2's have the same tank except the very late ones (89>) with the small sender hole.
I think the pipework inlets/outlets are slightly different too so they are not compatible.
Old Oct 18, 2010 | 08:22 AM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Basically there are two types of tank for the mfi s2
88 Spec - large sender hole
90 spec - small sender hole
You just need to swap the 90 spec one you have for the larger 88 spec one - as you see from the pics the pipe locations are slightly different and the sender size is completely different.
** NOTE ** A large number of 90 spec cars did still have the 88 spec tank on it tho so its not unusual to find an 88 spec tank on a 90 spec car (used to clear ford stocks at the time as it wouldnt be noticed I assume)
Simples !!!
Old Oct 18, 2010 | 08:40 AM
chaffe's Avatar
chaffe
Turbocharging Technician
good info there s2turbsZVH also worth noting the efi tank would have no provision for the k-jet pump underneath as it runs an internal pump.
Prickly_buzz
Dec 7, 2017 09:52 PM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
