Help!
My son has just bought an ST 170, we need to change the passenger side sidelight, but are unable to get this out, is there an easy way of taking the headlight cluster out?which bolts do we have to undo? or can anybody suggest any other way of doing this,
Many thanks.
Many thanks.
Bolt at the top that you can see, then a bolt underneath, you may need to jack it up so you can get under to see it, or stick your hand up under and have a feel about, the head of the bolt points out towards the side of the car if you get what I mean. If you just undo the top bolt, you may be able to tilt the headlight forward just enough so you can get in there!
