cusom engine mounts needed please help
Old Oct 13, 2010 | 02:57 PM
fordnut170's Avatar
fordnut170
Default cusom engine mounts needed please help
hi all i have a 2004 focus st170 i had broke for parts. the idea is to put the engine in my 2000 fiesta zetec s. the only promblem is i need engine mounts and dnt know where to get them from !!! i am based in warrington so the closer to me the better. can anyone help????
cheers
josh
Old Oct 13, 2010 | 03:09 PM
chaffe's Avatar
chaffe
Turbocharging Technician
Make some yourself mate some 3mm plate, a drill, angle grinder and a welder and some patience is all that is required.
Old Oct 13, 2010 | 03:12 PM
fordnut170's Avatar
fordnut170
wat metal do i need use??
Old Oct 13, 2010 | 03:15 PM
chaffe's Avatar
chaffe
you can use an assortment of mild steel, 3mm up to 10mm plate, box section, angle, solid bar, pipe, anything you think will do the job and work well for you, just look at some factory steel mount for some inspiration, you will soon get the idea
Old Oct 13, 2010 | 03:16 PM
chaffe's Avatar
chaffe
http://www.google.co.uk/images?hl=en...ngine+&gs_rfai=
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
xr4x4rs
Aug 6, 2015 09:03 PM
