Cossie oil cooler setup, how to?
Old Oct 11, 2010 | 07:33 PM
Ridgey's Avatar
Ridgey
Default Cossie oil cooler setup, how to?
Whats the best way to connect an oil cooler onto a cossie oil system please?
thanks
Old Oct 11, 2010 | 07:35 PM
Sandwich plate between the block and the oil filter, MOCAL do a nice one, get one with a thermostat built in for good measure well worth the extra Ł15 or so over one without, then run pipes from sandwich plate to oil cooler and back.
Old Oct 11, 2010 | 07:39 PM
Ridgey's Avatar
Ridgey
There is already the Modine (sp) oil/water cooler between the filter and block.
Would it be best before that (next to the block) or after next to the filter ? I guess it wouldn't matter ????
Old Oct 11, 2010 | 07:51 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
yeah i tought about that as well. 4x4 has that weird extensin bit for the filter makes it a bit awkard
Old Oct 11, 2010 | 07:54 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
how much is an oil cooler roughy mate if you dont mind me asking
Old Oct 11, 2010 | 07:56 PM
Sticky.'s Avatar
Sticky.
Look at my resto Dave.
Old Oct 11, 2010 | 07:59 PM
left hooker's Avatar
left hooker
ditch the oil/water cooler but i fitted remote oil filter
Old Oct 11, 2010 | 08:12 PM
left hooker
also fitted oil cooler
Old Oct 11, 2010 | 08:47 PM
You dispose of/sell the original laminova cooler, and use just the sandwich plate, as it is a far far more effective cooler.
Old Oct 11, 2010 | 09:15 PM
left hooker
you will have to join the two water hose'es together
Old Oct 11, 2010 | 10:01 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
u can buy a kit to remote the oil filter and keep the original set up as well then u dont have to fuck about with the water pipes! and get it thermostate controled so u dont over cool your oil! mocal do the hole lot for about 140
Old Oct 12, 2010 | 08:01 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
where from guys, cant find them
Old Oct 12, 2010 | 08:13 PM
left hooker
http://cgi.ebay.co.uk/SIERRA-SAPPHIR...item5d2b2a5917
Old Oct 12, 2010 | 10:42 PM
ajamesc's Avatar
ajamesc
google mocal and ring them direct!
Ian1964
12
Jan 26, 2021 11:57 AM
155lee
Oct 27, 2015 04:55 AM
truffleshuffle
Sep 10, 2015 09:35 PM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
