Oil pressure
What should the oil pressure be at idle on a 4x4 saff? Just put an oil pressure gauge in and it reads 60 psi or so at idle. Is this about right? Haven't been out in it since I fitted it, just started the car to make sure everything worked ok.
cheers dudes
cheers dudes
Well, just been out for a run and the pressure at idle seems to stay at a constant 30psi. That seems to be a better figure than before.
What do other peoples run at? Just so I can get an idea as to whether my engine is still all ok
According to fords own workshop manuals minimum oil pressure at 850 rpm should be 1.8 bar or 27 psi, and at 2000 rpm should be 2.4 bar or 37 psi, From cold my own car shows around 80 psi on start up , dropping back to 50 psi when she's warmed up, idle pressure though is rather low at about 20 psi but this is probably due to the cars age and the fact that it has 130,000 miles under its tyres, its worth mentioning though that aftermarket gauges can be notoriously unreliable , especially if its accurate figures your after
Originally Posted by .:Paul:.
Plater, is the hose for your boost guage t'd off the MAP sensor hose?
Been out and thraped the cossie to within an inch of its life today which was muchos fun!!
When fully warmed up, the oil pressure is down to about 25psi - 30psi. I'm assuming this is OK following on from the feedback so if anyone else is wondering what is should be, now you know
SMILER258
Sep 28, 2015 09:04 AM
