erst timing
Old Oct 8, 2010 | 07:52 PM
MARTCOS's Avatar
MARTCOS
MARTCOS
Default erst timing
ello peeps
help!!
does anyone know where the timing marks are on a erst?
if anybody could help would be most greatfull!
cheers
ian
Old Oct 8, 2010 | 08:08 PM
homer j's Avatar
homer j
on the head it's behind the cam pulley. the arrow on the cam pulley will point to it when the arrow is pointing directly up. on the crank pulley side it's actually on the cam belt cover. this lines up with a small notch on the edge of the crank pulley.
hth
tom
Old Oct 9, 2010 | 08:41 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Read the setup guide i have written to help you from damaging your engine.
Old Oct 9, 2010 | 03:53 PM
rsmark86's Avatar
rsmark86
what for cambelt or just the timing.....
if its just timing its easist to take the flash gaurd and cap of and line the centre line on the rotor arm to the little slit on the edge of the dizzy....
and for the cam belt ... i would down load some pics from autodata ... its realy easy to do if you know how but if you dont mate might be worth getting someone who can.... as it aint just a case of tight is best
Old Oct 9, 2010 | 04:31 PM
xrmalin's Avatar
xrmalin
Where can your set-up guide be found please jano ?
Old Oct 14, 2010 | 03:53 PM
MARTCOS's Avatar
MARTCOS
MARTCOS
cheers people much appreiated, might be a while now untill i cum to the timeing as ive cum to bit of a problem.
one of the head bolts has snapped off which i didnt relise untill the other day when was about to start rebuilding and has put things to a holt.
just hopeing its gonna cum out!!
cheers
ian
Old Oct 27, 2010 | 02:10 PM
MARTCOS's Avatar
MARTCOS
MARTCOS
thanks peeps shes back up and running, took a while to remove the snapped bolt but got there in the end!!
cheers
ian
Old Oct 27, 2010 | 03:13 PM
rsmark86's Avatar
rsmark86
well done mate .... get some pics up mate
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
