big bore
Old Oct 8, 2010 | 05:23 PM
gus's Avatar
gus
Default big bore
how big can you safely bore a 1.6cvh?
Old Oct 8, 2010 | 06:20 PM
DazC's Avatar
DazC
A 1.5mm over bore works out at about 1660cc IIRC. I think thats the biggers piston available for direct fitment into a CVH (without straying to pistons designd for something else).
Old Oct 8, 2010 | 06:28 PM
rsmark86's Avatar
rsmark86
and im sure thats what safe gus and to get hight capacity they pu stroked crank and different lenth rods ect but will have to ask the professionals ... what about american tall block comes as 1800 them bored to 1900
Old Oct 8, 2010 | 07:16 PM
gus's Avatar
gus
yeah i didnt mean off the peg daz
mark's reading me mind i think
just wondering how far you can go safely before you hit the water ways
Old Oct 8, 2010 | 07:45 PM
homer j's Avatar
homer j
could you not bore out the original bores then fit liners to get a bigger bore with a stronger wall? i'd imagine you could go quite big with that if it's possible to fit liners to a cvh block.
Old Oct 8, 2010 | 07:50 PM
gus's Avatar
gus
yeah thought about that
think i just spent that 112 mil from the euro tonight
Old Oct 8, 2010 | 08:06 PM
homer j's Avatar
homer j
lol that'd be one seriously expensive engine my man.
Old Oct 8, 2010 | 08:13 PM
phil_rs's Avatar
phil_rs
yam yammer
My 1.9 is based on a 1.6 block but is bored and stroked to get the extra capacity. I have no idea how though lol. IIRC Power Engineering used to do a systems 2 1.9 with just oversized pistons and were prone to failing
Old Oct 8, 2010 | 08:20 PM
gus's Avatar
gus
yeah i heard about that
Old Oct 8, 2010 | 10:47 PM
RSandy's Avatar
RSandy
werent the power engineering 1.9 conversions done using some crazy combination or merc pistons and triumph rods, or something weird like that?
and im fairly sure phils is a jamsport special block, best to ask them the exact spec of how they achieve it, but im fairly sure i remember it involving 1.8t audi pistons
Old Oct 8, 2010 | 10:52 PM
rsmark86's Avatar
rsmark86
jamsport do a good 1900 but it aint cheap as your needing uprated crank/rods/pistons/ ect ect
Old Oct 9, 2010 | 08:21 AM
muz's Avatar
muz
Wye Valley Hardcore
I thought a 1.5 mm overbore on Accrilites resulted on something like 1740? Or am I imaging it?
Old Oct 9, 2010 | 09:53 AM
Hansenturbo's Avatar
Hansenturbo
power engineering 1.9 use 83mm bore i have cracked one block
running 1.6bar
Old Oct 9, 2010 | 10:04 AM
DazC's Avatar
DazC
Depends on a few factors like piston height and combustion chamber volume but my engine on a 1mm overbore is 1640cc. I could bore it to 1.5mm but to reach 1740 i'd have to look further than just bore size.
Old Oct 9, 2010 | 10:08 AM
DazC's Avatar
DazC
If I was to go down the road of increased capacity, I'd get a spacer plate cut from a head gasket and bond it to the block. I'd then liner through the whole lot and use a longer stroke crank and longer rods.
Old Oct 9, 2010 | 10:10 AM
gus's Avatar
gus
yeah we spoke about that but tommy is fancying the idea of short stroking and bigger bore
was only a short chat as he was on the dyno at the time, so will need to sit down and go thro it all properly
Old Oct 9, 2010 | 07:25 PM
marky_g's Avatar
marky_g
Fleet Manager
no there cast at 1900 in the us but 1800s have been bored to 1900
speak to specialised engines
http://www.specialisedengines.co.uk/index.htm
Old Oct 9, 2010 | 07:31 PM
marky_g's Avatar
marky_g
Fleet Manager
aint that a harvey gibbs conversion i was offered a 1700 apraently gibbs built
Old Oct 9, 2010 | 09:15 PM
DazC's Avatar
DazC
To destroke will reduce the capacity but make it revvier. The issue then is the valve train as it's not good for high revs. The CVH is rev happy anyway up to 7500 rpm. This is also the point where valve heads like to drop off.
I'd sooner try to keep the rod ratio as it is (by increasing the length of the rods as well as the crank) and increase the capacity by increasing the stroke as I know there is only down sides to trying to rev over 7k rpm.
Old Oct 9, 2010 | 09:28 PM
gus's Avatar
gus
yeah this is what i said
but he was double busy on thedyno so didnt really go into anything
Old Oct 10, 2010 | 08:43 PM
Rob_DOHC's Avatar
Rob_DOHC
Gus.... why not a zetec? lol or is this all hypothetical?
Rob,
Old Oct 10, 2010 | 08:51 PM
gus's Avatar
gus
should do really as its alot easier
but
i like the idea of keeping the cvh
its o hypothetical no, i will be doing it as and when i can afford to
Old Oct 10, 2010 | 09:27 PM
Rob_DOHC's Avatar
Rob_DOHC
I love the idea of sticking with cvh's too mate, but i guess when you look at it.... there is only so far you can develop a cvh bottom end until its not too unlike a zetec bottom end....
Rob,
Old Oct 11, 2010 | 12:15 AM
rsmark86's Avatar
rsmark86
to be honest if i done another i would zetec turbo it .....
and my missus is having a supercharged duratec fitted in her rs1600i shell... although i keep telling her to zetec turbo the thing
Old Oct 11, 2010 | 09:28 PM
DazC's Avatar
DazC
Tell her to ditch the supercharger and get a turbo on there instead! Duratecs (true Duratecs) make shit loads of power.
Old Oct 11, 2010 | 11:15 PM
rsmark86's Avatar
rsmark86
its a st150 engine but will be on after market management.... with cams /cosworth inlet/ custom exhaust manifold and system and with a stage2+ supercharger it will be 300/320bhp..... and its gunna be used on track aswel...
i spoke to jamsport a few times and about it and at this spec they have still used standard internals lol and its still reliable the weak point is the gearbox but they reckon with a quiafe atb fitted this seems to make the more reliable for some reason
stevecfrst1
Sep 30, 2015 05:18 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
20/20 vision
Sep 28, 2015 03:03 PM
SMILER258
Sep 28, 2015 09:04 AM
