Turbo advice ?? but for an A series mini !
Morning gents , am not realy sure where to put this so am sure mods will let me no.
Anyway, you guys have a lot more turbo no how than i do, now ive been told the T3 is old hat and to get a more modern turbo.
My engine is basicly a metro turbo motor but spec is as follows
1293cc
Forged omega pistons
lightened/ ballenced crank and rods
36.0 and 30.0 valves are 21NS stainless steel and plasma nitrided with waisted stems on both inlet and exhaust and 3 angle valve seats, new silicon bronze hi-flow valve guides.
1.5 roller rockers
Kent 266 cam
11 stud head as aposed to 9.
running 7.5:1 compression
utralight steel flywheel
ap padel clutch
Jackknight straight cut gear box and atb diff.
Now some of you may understand that but am sure will be baffled.
Most of the miniturbo lads are running a gt17 from a saab
but im looking into a gt2056 that iveco and renault vans use .
Am just wandering if any of you guys could help and advise on somthing that is easly available or better, i beleve on my com ratio a could runn 25-30psi
Can ANY one help me the lads on the turbominis site are brilliant but ive owned loads of fords aswell so would realy value your comments.
Thanks Rick
1293cc
1.5 roller rockers
Kent 266 cam
ap padel clutch
Thanks Rick
Mini a series that brings back memories, I had a souped mini had a ex stud nicklaus sprint engine, stroked crank and relieved block for 1558cc I think it was, went like stink that was t3 on a cut down 45.
Anyway T3's could be described as old hat, wing to the vastly better from a lag point of view GT series with roller bearings.
I'd be cautious about using a turbo from a tdi, but if it would take the temp why go the whole hog and use a variable vane turbo as fitted to some tdi.
Why not efi it and use management be even better then ?
Turbocharging Technician
I know a lot of the R5 boys use the vag VNT turbos, as they have variable AR exhaust housings, to reduce low down lag but still keep the engine free breathing high up.
have forwarded these questions to a colleague who has built several mini turbos in the past
will post up his responses shortly
also if you can get hold of tom fenton on turbominis, he knows his stuff (tell em rory says hi, i was at uni with him)
We i do have a better spec race head for it and with the old t3 i was only running a bar of boost and would easly do 7k and aseamed to want to go more.
They do a specific turbo cam aswell but this wasnt available at the time when i had the engine built many years ago, it was only run for 18 months or so then escort cosworths and the likes get in the way .lol
Been re building it the last few years now into a track car rather than road.
So come on chip then it sound like your my man!!!!
Thanks Rick
ps, carnt use managment at the mo with the siamese ports? on the standard 5 port head
Thanks Rick
Hi, yes i no tom myself him and carl austin (forceracing ) have built a twincam 16v head on the mini and last 1/4 mile run was 11.1 i beleve. Very impressive front wheel drive.
rick
You can put EFI on Siamese ports but you'd need massive flow rate injectors (Standard MPI's run 470cc I believe) or Single Point Injection (as said above).
Serious engine though
. Whats the max that the JackKnight boxes can take? PM AlexF about turbo choice, he does alot of turbo mini's.
. Whats the max that the JackKnight boxes can take? PM AlexF about turbo choice, he does alot of turbo mini's.Dont realy want to get too involved with the injection to be honest, if anything does happen it will be a long time off but there doing a 7 port alloy crosflow style head that i could still use this turbo/manifold combo but with a plenum up front on a single throttle body. dont want to get into that yet theres so much more development to do with the car as its a one off spaceframe ive been building but ive had the said engine in a standard mini allready.
Oh and ive got a dog box if the syncro straight cut gives up.lol
Rick
Oh, and with all the effort you have i'd ditch the carb. So much to be gained with something efi. It's much more reliable once running. If you were near Manchester i could help you with all the management etc.
Rick
Rick
Rick is the ko4 same a like seat leons etc, maybe next winter for the efi bit , i just want to get the dam thing sorted it been too long, ive had a few opp's latley and were crazy busy at work aswel so it allways comes last. Plus theres going to be loads of development with suspension an brakes, runnig separate remote master cylinders a 6pot calipers up front.lol
rick
ps im just other side of you , huddersfield/wakefield area
rick
Rick,
the K04 is used on the Seat cupra, Audi TT and Audi S3. K03 is used on the low power VAG 1.8's, which develop 150-180 as std. There are loads of these around so you could experment with a KO3 then goto a KO4 if you want more.
Wakefield isn't far, so get in touch if you need any help with the megajolt side of things, fully mappable ignition is already going to be a huge bonus.
Rick
Rick
So do you think the gt2056 couldnt cope with the high boost temps with it being off a deisel, the gt 17 the other lads use is just for road cars and drag strip runs, so thats why i think they havent had probs.
Thanks for the offer on the ignition rick, i may take you up on that bit it will be in the new year.
rick
rick
i'm building a mini turbi just now,
pretty standard not in the same league as yours(very nice btw),
i'm just wondering if an old su could possibly cope with 25-30psi stuck up its arse?
Yep built properly theres matt woods hes a photographer for the mags , yes he runs gas aswell but has made over 300hp with it. but rebuilds and checks it every winter.
The su on na wont do the power but as its forced induction its fine.
Rick
Rick
Sorry gents to keep pestering, a friend had some flanges cut so i got him to do me some for the gt2056 so that would be the ideal turbo to stick with, just wandering if you turbo buff's think it will do what it should.
thanks rick.
ps Oh ive had a phone call and i may be back in cosworth ownership soon, keeping it quiet at mo incase it doesnt come off.
thanks rick.
Well the shell with frame and steel doors was 430kg
I now have alloy doors ,plastic windows but its all the wireing water and fuel lines etc that will add up. Id be happy at 550kg
rick
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Funny enough was talking to my friend Matt yesterday about the same thing, he's thinking of a change on his Mini turbo (best figure to date with his A series 310bhp iirc) think on a T3, haven't got the rest of the spec to hand
You could sign up on turbominis.co.uk for advice?
Is that a certain matt woods, yes i no who you mean ,he runs gas aswell to get those figures, im on turbominis quite alot they all seam to be using gt17 from a saab, i was just wandering from some of you turbo boffins on here wot they sugested. think im going to try the gt2056.
Rick
Why not put another engine in it? you have gone to all the work of making that lovely space frame and getting the shell all minted up, Will a 16v from a metro not fit? or a big bike engine?
lol I've known him for 10 years and never knew that
what do they say about women never listening
granted it's also been about 8 years since I've been in it
(although common sense says it must have a shot)
Had a feeling you weren't completely new to minis by the pics above
(although common sense says it must have a shot)Had a feeling you weren't completely new to minis by the pics above
Im a mini person, had one before i could drive etc, and beleve a mini should have a mini engine in it.lol (could be stupid jut my thaughts)
But then again ive cut it all up and made it into a spaceframe, so there is just the outer (steel though ) shell.
Theory being minis rot for fun , so this one shouldnt and it will be allways somthing i will keep and its a one off.
Saying that ive had two escort cosworths and loved every second i owned them, cousin had a series one, and i used to use that more than him when i was 18 lol .
Am just on with trying to get another rs at the mo as there a passion of mine aswell.
Rick
I understand the ethos with keeping the A series mate, otherwise none of the original car would excist lol! just thought somthing a bit more modern, would suit your modern space framed approach. A hyabusa turbo or something of that flavour, light, powerfull and reliable, if a little missing on the reverse front! keep up the spotless work though, very good soo far.
Awsome, well once it gets warm it puts flames as high as the spoiler.lol, i can only see it when its dark but wen the lads have been following says its ace i just need a pic of it.
Anyhow, still no one got anymore turbo advice for me or wheres best it speek to.
Am wakie west yorks
Rick
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
