Any Vauxhall Techs in the house
Old Oct 7, 2010 | 07:34 PM
LHD220Turbo's Avatar
LHD220Turbo
Default Any Vauxhall Techs in the house
sisters car
2004 (04) plate Astra SRI 1.8; pretty sure its an immobilizer problem.
turn ignition on, the symbol of the car&spanner (yellow) continuously flash; nothing happens, doesnt even crank.
tried the spare key and the same problem; i think the key fobs have lost their code?
anything i can try and do?
cheers
matt
Old Oct 7, 2010 | 07:38 PM
BLACKCOS's Avatar
BLACKCOS
crank position sensor
Old Oct 7, 2010 | 07:46 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
ok according to autodata
system fault present
needs proggramming via diagnostics equipment mate
Old Oct 7, 2010 | 07:47 PM
LHD220Turbo
CPS wouldnt stop it from cranking over
Old Oct 7, 2010 | 07:49 PM
LHD220Turbo
i thought that might be the case; but i really dont want her to take it to "main stealers"!
as its immobilizer i think it will be the only option
the old vauxhalls you could reprogramme the key fobs by following a sequence but not sure you can do it on hers
Old Oct 7, 2010 | 07:53 PM
creator's Avatar
creator
Main dealers I'm afraid mate,they shouldn't charge much as it's only a 2minute job to program the transponders and immobiliser.
Old Oct 7, 2010 | 07:55 PM
LHD220Turbo
any ideas what it should cost?
Old Oct 7, 2010 | 07:56 PM
creator's Avatar
creator
But saying that I can't remember of the top of my head if that astra will require it but vauxhall bought out a software update for the cim module to stop it causing this fault.
Hth
Old Oct 7, 2010 | 07:58 PM
LHD220Turbo
cheers
Old Oct 7, 2010 | 08:04 PM
creator's Avatar
creator
No worries mate.if you were closer I could of sorted out for you mate.
Old Oct 7, 2010 | 08:05 PM
LHD220Turbo
thanks for the offer, appreciated
she'll have to go to Vauxhalls
Old Oct 7, 2010 | 08:08 PM
taz1787's Avatar
taz1787
try a garage using snap on diagnostics kit rather than main dealers mate might be worth a shot first
Old Oct 7, 2010 | 08:11 PM
creator's Avatar
creator
No worries mate.something to try tho to get it running if all it needs is the software update try turning the ignition on and of 6 times then try and start it in the 7th time if that makes sense.
LHD220Turbo
but then it wont be able to reprogramme it?
Old Oct 7, 2010 | 08:14 PM
martysmartie's Avatar
martysmartie
Have you tried resetting ECU? Agreed immobiliser problem just seems strange it's lost both keys.
Martin
Old Oct 7, 2010 | 08:16 PM
LHD220Turbo
Martin
nope; how? is it the same ecu for the engine & immobilizer?
cheers
Old Oct 7, 2010 | 08:27 PM
taz1787's Avatar
taz1787
because it can access ecu functions and their is alot of info that can be accessed from a snap on diagnostics machine its basically the same machine that main dealers will use
Old Oct 7, 2010 | 08:28 PM
taz1787's Avatar
taz1787
to reset ecu disconnect battery for a period of time ( some are 30mins some take longer some overnight etc)
Old Oct 7, 2010 | 08:32 PM
martysmartie
What he ^^ said. Although you just need to remove the KAM fuse on Fords, but just D/C the battery for 10 minutes as this is easiest.
Martin
Old Oct 7, 2010 | 08:45 PM
taz1787's Avatar
taz1787
Martin
easiest and safeist to d/c the battery
Old Oct 7, 2010 | 08:49 PM
martysmartie
Not neccessarily as the fuse protects the memory so if removed no power so does the same thing and saves you D/C battery, make sure if you D/C you have relevant radio codes etc, if applicable on the car.
Martin
Old Oct 7, 2010 | 09:09 PM
taz1787's Avatar
taz1787
it wasn't a dig mate but seen so many people blow ecu removing & replacing fuse mate thats all
Old Oct 7, 2010 | 09:12 PM
martysmartie
Oh no LOL diden't take it as one, just was saying, as you say the easiest way is to D/C battery.
Martin
Old Oct 7, 2010 | 09:34 PM
cossie604's Avatar
cossie604
If it is the cim then your looking at main dealer only anyhows as it'll need configuring (you'll need your security pass also mate)....most main dealers will discount the diagnostic cost from the repair costs also.
Old Oct 7, 2010 | 11:41 PM
155lee's Avatar
155lee
might sound stupid but have you tryed bump starting it?
Old Oct 7, 2010 | 11:48 PM
botters's Avatar
botters
competant bodger
+1 works on older clios! might be worth a shot
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
fordrallycar
Sep 30, 2015 07:57 PM
