fuel rail question
Old Oct 6, 2010 | 04:52 PM
bad boy rs's Avatar
bad boy rs
Default fuel rail question
Ive got a 2wd fuel rail with a -8 feed braised on, eventually im going to braid the lines all the through but is it safe to cut the original feed and jubile the pipe over the original ?
or can i get a fitting that will use the original joint on the inner leg ?
cheers paul
Old Oct 6, 2010 | 05:55 PM
If you're meaning to put the hard plastic pipe over the -8 then defo no, a jubileee won't seal it properly it's just too rigid, if you mean a bit of rubber flexy pipe onto the -8 inlet of the fuel rail then will seal perfectly, as pressure goes 10 bar is nothing.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
