please remove
rs turbo bare head £30
90 spec interior front seats very good condition no front door cards £120
rs turbo s2 carpets £25 each
parcel shelf £40 each
bits that cover rear turrets in boot £20 pair
fiesta turbo bottom end with mfi turbo head £ 170
efi inlet manifold £20
t3 turbo with manifold actuator £80
escort turbo down pipe £20
red bailey dump valve £30
silver bailey dump valve £30
rs turbo inlet manifolds £15 posted
dizzy £30
88 spec cross over pipe £10
samco blue s2 top dump valve out let £10
dizzy £30
[quote=stuart collins;5121121]
ofab ecu and loom , super chip and beige injectors cam off fst runnin 191bhp, missing a few sensor plugs £200
whats need to get this working
[QUOTE=mr_joe0606;5124441]
Hi mate, the easiest route is to put an xr3i efi loom and tank into your car and then just plug and play all the frst stuff into the 3i loom. For more detailed description go onto www.rsbible.co.uk cheers tomo.
[QUOTE=Tommys1turbo;5128276]
this is defo a cheap option but findin an efi xr3i full loom is a nitemare,can an mfi tank and fuel pump be used on efi?
[QUOTE=rickbartlett;5128326]Allright mate, yeah it is cheaper option, you can retain the rst tank and pump just need to adjust the wiring accordingly..
