fuel pipe i.d
hi anyone know the internal diameter of fuel pipe from the metal pipes to the fuel rail and from the fpr back to the metal pipes i think its about 8mm but not sure, cheers
Std is 7.8mm from memory, as said 8mm is fine, can use OPA, the SYTEC fuel pipe is very good also, some OPA seems to have a short life, but the sytec supplied opa seems much better than most.
155lee
Sep 6, 2016 11:10 AM
