how to identify sierra cosworth camshafts
Old Oct 2, 2010 | 07:01 PM
omegadesignsolutions's Avatar
Default how to identify sierra cosworth camshafts
just a thought... i was told by the last owner the yb had standard cams.how can i identify them conclusivly?were the std cams BD8 OR
BD10`S?
cheers
matt
Old Oct 2, 2010 | 08:42 PM
Alvyn's Avatar
Alvyn
Bd10's aren't standard cams!
Old Oct 3, 2010 | 09:49 AM
BD8 are standard, but won't have BD8 written/marked on them.
I wrote down the markings on my std 2wd cams if you want me to dig them out and put up ?
Old Oct 3, 2010 | 10:43 AM
Toe Knee's Avatar
Toe Knee
Anything other than standard will, or should have bd10 etc stamped on the end of it. As said standard ones don't. Only prob going by the markings is it could be a reground cam!!
Old Oct 3, 2010 | 01:40 PM
just looked at the cams-they both have YN0011 on them also one has lyd2,the other lyd 3??
Old Oct 3, 2010 | 03:35 PM
Mine have LYD4 on the exhaust cam, with LYD2 on the inlet both also with YN0011, so looks like std, just measure the lift, measure the lobe with a vernier to see how high it lifts from the base circle, should be 8.554mm for a std cam inlet or exhaust.
3dr cossie
11
Dec 21, 2015 03:38 PM
andyrs1600i
Aug 30, 2015 07:21 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
