Power steering pump pulley question ?
Old Oct 1, 2010 | 07:23 PM
Mark V8's Avatar
Mark V8
Default Power steering pump pulley question ?
Does any one know if the serpentine belt pulley will fit the V belt power steering pump ?
thanks for any info
Mark
Old Oct 1, 2010 | 08:22 PM
99.9% sure it does, never known a difference in pumps so each pulley fits the one pump ?
Old Oct 1, 2010 | 10:16 PM
Mark V8's Avatar
Mark V8
Cool, thanks tabetha
I don't suppose you know the rough O.D of the crank pulley for the serpentine belt cosworth engine ?
I'm using a 2wd cosworth power steering pump on my V8 5 door and have a feeling that the V8 crank pulley might overspeed the power steering pump
Mark
Old Oct 2, 2010 | 02:18 PM
No, I don't have a serpy to hand to measure either, unless the crank pulley is a huge amount bigger it will be ok, I've used the std pully pump crank pulley at 7800rpm.
martysmartie
Sep 6, 2015 10:22 AM
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Jay,
Aug 24, 2015 05:26 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
