Escort or Sapph 4wd front cross member and steering rack
Not straightaway i guess, drop it over if your passing and we can have a cuppa .
Doug , this is for an Escort mate , the Lexworthabushiyota is away getting paint currently
Well if u only need something to stick on it for now till u sort something that's fine mate!! Can drop it off sat hopefully. Probably a good idea if I kept the rack as a spare but your more than welcome to borrow them till u get what u need!!! Any other bits u after?! I'm having a clear out lol
Right rear 2wd Driveshaft , Pair of the plates that go under the rear beam mounts if you have some good ones ,Escort Cosworth dash and banana ( doesn;t need to be very good as its getting chopped around a cage ),
compression struts , Adj tCA's for 2wd pinchbolt type ,front WRC top mount steel rings , 4wd Steering column knuckle , scruffy Escort Morettes without centre lamps , Escort Cos rear lamps , Escort cos car wiring loom , windscreen wiper motor and mechanism ,scuttle panel etc..
Karl 3dr
102
Oct 14, 2016 08:17 PM
