Oil pump testing
Is it possible and who could do it?
Basically have a newish one that came with block etc but with the money i'm about to plough into it i want to be sure - i know new are cheap enough but want this one checking first.
The easiest way of testing is in a engine, don't need to run it spin the dizzy/pump shaft, but otherwise would need to make a fixture so you can collect/contain the output from the "D" shaped hole insert the strainer/pick up in oil and spin.
Not sure if my engine place has a pump test rig, doubt it as new ones only £24, but can ask if you want ?
jonfoc
16
Sep 11, 2018 05:35 PM
truffleshuffle
Sep 10, 2015 09:35 PM
