brake servo vacume feed?
hi all just wonderd what people do if there not running abs on there cossy engine,as there is no vacume feed for the brake servo,
was thinking of drilling and tapping the plenum
thx all
thx all
Yes they do not have conventional brake servos, I.E vaccum feed.
Instead they use an electric pump setup, you can do away with the ABS and leave the electric pump (Servo) as it is now.
Martin
Martin
I'm not sure with the V6 cossie, but obviously if it has a std diaphragm servo then as you say just get a vacuum feed to it for it to work, I didn't think they had a conventional servo but not sure.
step 1. Buy an aftermarket breather
step 2. use the one way valve from your old breather setup to feed your servo.
Worked for me!
*edited to note that i used a conventional servo/master cylinder setup when my ABS went wrong*
Worked for me!
cheers all ive just tapped a fitting in to the plenum for the vacume
the brake servo is off a xr4i i use 1 of these as these have the biggest master for non abs systems
