mk2 mondeo, what to do?
right after a failed buy with a red modified ford ka ive turned my attention to my mk2 1.8 silvertop zetec mondeo, as i bought it from ebay for the cheap sum of £243 witha knock at the rear, dent in the passenger side wing and some rusty rear arches, now ive sorted them things out and got a genuine RASP ST24 kit fitted that just needs painting and some 5 spoke 17s coming soon, is their much else i can do with this car, even the simple mod ideas will be a step in the right direction lol
if you go for 2ltr cams you'll need the 2.0 ecu as well.
supercharging, turboing or throttle bodies will give nice performance gains at a price.
upgrading the brakes to the mk3 mondeo ones (260mm to 300mm) is an easy job for the fronts and a bit more involved on the rears. for a bit more work then the asbo focus brakes will fit with Focus RS 324mm 4-stud discs but check your rim clearance. there are lowering springs/kits available which will help with the stance instead of it looking like its on stilts.
take a look on MEG (now talkford) there's a wealth of info on there.
wowk
Mar 30, 2021 07:49 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
The Enigma
Sep 29, 2015 10:31 AM
