is there anywere i can get a male cosworth ecu main plug.
im debating on changing my ecu but i have a fairly new loom.
can you get a plug that looks identical to the ecu pins so i can make a short loom to put onto existing plug and then my new ecu plug on other end so i can just plug and play?
You can get them, £135 last time I checked, so expensive as short supply, even back then about 1 year ago it was seriously short supply, you could always double up the wires in the loom plug then fit another ecu end on there to get same result a lot cheaper.
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
