Pic req; how much is your saph lowered by?
Old Sep 27, 2010 | 01:31 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
Default Pic req; how much is your saph lowered by?
There is a reason why i ask this - my saph is on koni springs/dampers but i dont know what its lowered by but its too low... i want to keep it on the konis but not sure what drop i want;
heres a few of mine:
cheers
Old Sep 27, 2010 | 03:44 PM
Moonstone Mo's Avatar
Moonstone Mo
Konis all round 20mm on front 25 on the rear.
Old Sep 27, 2010 | 03:47 PM
Moonstone Mo
A before and after for you aswell mate.
Old Sep 27, 2010 | 05:17 PM
saph cos rob
swindon rsoc
looks good mate cheers
Old Sep 27, 2010 | 05:47 PM
Moonstone Mo
i reckon the stance yours has now looks the nuts
Old Sep 27, 2010 | 06:08 PM
saph cos rob
swindon rsoc
yeah i love it only ive ground out 2 exhausts now and cant get it in any of my local MOT testing stations without taking the front bumper off... i recon highering it by 10-15mm will sort it only i havnt a clue what its at now,,
Old Sep 27, 2010 | 06:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Konis and bayjoo springs
Old Sep 27, 2010 | 06:22 PM
Chopshop85's Avatar
Chopshop85
Originally Posted by saph cos rob
That is my favourtie saph!. Looks fantastic.
Old Sep 27, 2010 | 06:33 PM
saph cos rob
swindon rsoc
kev - i love they way yours sits, any idea on what they lower it by?
yours has to be my all time favorite saph,,
Old Sep 27, 2010 | 06:49 PM
KSA-Cossie's Avatar
KSA-Cossie
Thanks Rob,yours does look good m8
Lower by 10-15 mm m8,brilliant springs imo.
Old Sep 27, 2010 | 06:53 PM
saph cos rob
swindon rsoc
everyone has been telling me to go for bayjoo springs to match my koni's... im guessing yours comps are 18's too? if my sits like yours id be happy
Old Sep 27, 2010 | 07:04 PM
KSA-Cossie's Avatar
KSA-Cossie
Do it Rob,springs are worth the cash,so is an adjustable rear beam to make it handle even better. I swore my big monet spending was done after the engine but ive still done 3k this year lol.
Old Sep 27, 2010 | 07:08 PM
saph cos rob
swindon rsoc
There money pits lol where did you get your bayjoo springs from? seems like a mission to get hold of them now...
Old Sep 27, 2010 | 07:23 PM
KSA-Cossie's Avatar
KSA-Cossie
Mike Rainbird m8,think they're on back order best give him a bell.
Old Sep 27, 2010 | 08:40 PM
DJMST's Avatar
DJMST
SHELL GARAGE VIP
Whats the script with lowering a 4x4 saph,thought it couldnt be done due to drive shafts popping out.
Kev,yours looks the nuts mate,sits at a nice height
Old Sep 27, 2010 | 08:47 PM
johnnysierra's Avatar
johnnysierra
they all look pretty bloody good to me
Old Sep 27, 2010 | 09:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Cheers pal.
Old Sep 27, 2010 | 09:35 PM
Cosworth Lad's Avatar
Cosworth Lad
avos all d way m8[[IMG]http://i956.photobucket.com/albums/ae48/tabz2/th_Image0379.jpg?t=1285623238[/
Old Sep 28, 2010 | 08:33 AM
James_RScos's Avatar
James_RScos
Im on Konis and standard ride high Bayjoo spring(and poly bushed all round apart from rear arms(standard ford)), cant speak highly enough of the setup, Mr Rainbird to thank for that!!
Old Oct 7, 2010 | 08:02 AM
dazzle740's Avatar
dazzle740
As already said Koni's with Bayjoo springs best set up imo before coilovers, to an earlier question you can lower 4x4's but if you go too low then you get the front driveshaft popping out issue athough it can be solved by fitting xr4x4 shafts as they slightly longer but won't happen with bayjoo springs.
Old Oct 7, 2010 | 08:05 AM
dazzle740's Avatar
dazzle740
KSA-Cossie loving the comps mate but can I just ask what offset are they and what size tyres you use, do they rub at all or have arches been rolled only asking as I might be able to get my hands on a set for mine.
Old Oct 7, 2010 | 08:09 AM
saph_Al's Avatar
saph_Al
20mm avo springs on Konis for me "see Sig"
Cheers Al
Old Oct 7, 2010 | 08:57 AM
KSA-Cossie's Avatar
KSA-Cossie
ET35 8x18 215/35/18 m8.
Old Nov 9, 2010 | 12:14 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Just to let you know that the Ahmed springs are currenty in stock for all Cosworths .
Old Nov 9, 2010 | 08:14 PM
skinnarbi's Avatar
skinnarbi
Tyres - It's What I Do
can you fit cosworth suspension to a non-cosworth? or are the hubs different ect, ive got a 1.8 glx but the better suspension setups seem to only be for a cosworth
Old Nov 9, 2010 | 08:23 PM
martysmartie's Avatar
martysmartie
Yep any 2WD strut will fit any 2WD hub just watch overall tyre size as the Cosworth has a lower spring pan.
Martin
Old Nov 9, 2010 | 08:30 PM
skinnarbi's Avatar
skinnarbi
and the rear setup is the same? if i was to fit standard cosworth items will it lower my car? is the ride hight the same?
Old Nov 13, 2010 | 02:50 AM
akilles's Avatar
akilles
Old Nov 14, 2010 | 01:07 PM
Paul_RS's Avatar
Paul_RS
On Bilstein coilovers.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gcfcos
88
Sep 15, 2015 03:48 PM
rsturbo27
Sep 5, 2015 05:08 PM
