bias pedal box
Old Sep 26, 2010 | 08:53 AM
andyberg's Avatar
andyberg
Default bias pedal box
this must have been asked before but i cant find any posts . if i use a bias pedal box in mk1 cossy conversion do i need a servo if so which 1 and where do i put it
Old Sep 26, 2010 | 09:07 AM
JonnyBravo's Avatar
JonnyBravo
No you don't need a servo. The cylinders are mounted on the back of the pedal box.
Old Sep 26, 2010 | 11:09 AM
andyberg's Avatar
andyberg
thanks for that as i wasnt quite sure
Old Sep 26, 2010 | 11:36 AM
rubinsbin's Avatar
rubinsbin
standing looking at the car from the front on the right hand side the m1 borehamworks cars had two servos.(one for front brakes and one for back brakes!!!-)
but your not building a replica are you?-not with a yb in it anyhow-lol .
Old Sep 26, 2010 | 02:11 PM
andy escos's Avatar
andy escos
if you are using a bias box do not use a compbrake one they are crap the pedal ratio is 3.5 to 1
if you can get a pedal box around 6to 1 that would be better here is a floor mount one
http://www2.obp.uk.net/catalog/produ...4661f56de4b53b
if you fit a servo it will dramatically improve your braking ability
Old Sep 26, 2010 | 06:28 PM
JonnyBravo's Avatar
JonnyBravo
Personally I'd just use a Gartrac one
Old Sep 26, 2010 | 07:45 PM
whizzisat114's Avatar
whizzisat114
Im sure i read some where that if a car was made with a servo then it has to have one to pass the MOT Is this correct?
Old Sep 26, 2010 | 08:02 PM
mad russell's Avatar
mad russell
Volvo Mad
Yes its true but many an Mot tester would have no idea i run a pedal box and a dual servo works really well
Russ
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
