autronics or vipec..?
Old Sep 25, 2010 | 06:11 PM
gibbo frst's Avatar
gibbo frst
Default autronics or vipec..?
can someone tell me whats involved in running these on a cosworth.. does it use the original sensors and siemens injectors. does it do away with the distributor and ignition amp.. its for a 2wd cosworth with gt3076 currently on l8. or the other one ive seen on here vipec..?
thanks for any help.
Old Sep 25, 2010 | 06:18 PM
MikeR's Avatar
MikeR
PM Mark Shead, he is the UK distributor for both and he has done god knows how many installs he would be the best bet to answer your questions with certainty
Mike
Old Sep 25, 2010 | 06:21 PM
GARETH T's Avatar
GARETH T
theres a few problems in "doing away with the distributor" on a yb, firstly, the bottom half of the dizzy shaft is used to drive the oil pump, secondly if you want to run full sequential fuel injection you will need to have a sensor on the cams to sense engine phase (remember the cams more at half crack speed)
Old Sep 25, 2010 | 06:22 PM
GARETH T's Avatar
GARETH T
by the way, why are you moving away from the L8?
Old Sep 25, 2010 | 06:23 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Vipec is by far the better option just in terms of customer support, Autronic fail horribly on this front.
I personally love the Autronic though, and wont be swapping my SM4 for viped, Im too used to it now and I really do prefer the mapping interface on it as well (think even sheady does TBH, its very good once you are familiar with it)
As MikeR mentions, Sheady is the UK's leading authority on both these ecu's and hence the only person worth listening to really!
Both will work on cossie sensors, although they run their own map sensors instead (autornic is internal, not sure on the vipec) and I think Mark will prefer using a quicker reacting airtemp sensor than the cossie one.
Old Sep 25, 2010 | 07:02 PM
gibbo frst's Avatar
gibbo frst
thanks for getting back i think ill ring him on monday.. im having problems with my setup at the min where the car will run then all of a sudden revs up and down then starts missing revcounters going mad then it dies.. crank it back over and theirs no spark. had to get the rac to lift the car home last week on my way home from work which made a 3 hour journy 10 hours.. ive replaced phase sensor rotor arm and cap , leads crank sensor ignition amp and engine loom all for brand new and its still not working. was only mapped a few month ago. i just thought as it seems so many people have this same problem and cant seem to cure it if i could do away with the dizzy ect for a more modern setup couldnt do any harm.
Mark Shead's Avatar
Mark Shead
Both as good as each other, the Vipec is over £500 cheaper than the Autronic,
On the Autronic you remove two lugs of bottom pully and one of the dizzy,
You can still use the stock coil and dizzy for the spark or a coil pack or 4 coils which is what I normaly use,
The Vipec can use all the stock sensors.
Mark
Old Sep 25, 2010 | 07:30 PM
gibbo frst's Avatar
gibbo frst
thanks for that .. ideally id like to do away with the cap and rotor arm setup.. would i need a loom making up for these or do i modify my existing one.. also would you say that autronic is worth thr 500 extra.. ill call on monday about prices ect..
Old Sep 25, 2010 | 07:35 PM
Mark Shead's Avatar
Mark Shead
I would recomend making a new loom and running 4 coils,
The price diff is £800 if you are using 4 inj and £400 if you need 8, They are both as good as each other so its up to you to which you want.
Mark
Old Sep 25, 2010 | 07:48 PM
GaryHurn's Avatar
GaryHurn
get the v44 great unit and great price
Old Sep 25, 2010 | 08:12 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
what the current rrp on autronic and vipec mark ?
looking at management atm ,
and planning to run c-o-p , dizzlyless ,
beef
Old Sep 25, 2010 | 08:14 PM
Mark Shead's Avatar
Mark Shead
beef
I cant put the price up as I am not a trader on here.
Mark
15
Oct 7, 2015 03:43 PM
dumped
84
Aug 31, 2009 11:27 AM
RANJ
12
Apr 9, 2006 04:47 PM
keithcowie
31
Jun 23, 2005 01:16 PM
sunny
17
Jan 23, 2005 05:57 PM
