Sierra Cosworth 2wd rpm counter not working ...
Old Sep 25, 2010 | 12:19 PM
ThomasV's Avatar
ThomasV
Default Sierra Cosworth 2wd rpm counter not working ...
Hi everyone,
I have a '88 Sierra Saph Cossie and I have a annoying problem with my rev.counter.
It doesn't work ... but every once in a while it will, out of the blue, work again. If I turn the car off and on afterwards, it doesn't work again.
So, basically, it works 10% of the time ... :/
Anyone have any bright ideas ? ...
BR
Thomas
Old Sep 25, 2010 | 12:28 PM
martysmartie's Avatar
martysmartie
Check the green wire on the coil connection (-) this is the pulse for it.
Martin
Old Sep 25, 2010 | 12:52 PM
ThomasV's Avatar
ThomasV
Martin
Cheers mate ... will do that.
Old Sep 25, 2010 | 06:55 PM
Check VERY carefully the track leading from the green wire in the connector on the clocks to the tacho, the tracks are known to break and cause on off, I've rewired from connector direct to the terminal on two different ones, worked both times 100%.
Old Sep 25, 2010 | 09:58 PM
ThomasV's Avatar
ThomasV
I Will see if I can sort it tomorrow... Thanx alot for great advice.
Old Sep 26, 2010 | 09:47 PM
2wd's Avatar
2wd
Originally Posted by ThomasV
Hi everyone,
BR
Thomas
PM'ed ..
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
