toad alarm "wonky"
Old Sep 24, 2010 | 06:35 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
Unhappy toad alarm "wonky"
yep my batts been off the car for a while,on reconection ,my toad ai606 decided to do a turn,now it opens and re-locks the doors,so you have to use the key for entry,and when you drive, it unlocks the doors?,before ,it had anti-hyjacking,now i feel vulnerable,please help.how do i reset these .thanks in advance.colin.
Old Sep 24, 2010 | 07:24 PM
snoopaloopa's Avatar
snoopaloopa
Weird, Toads normally leave the door locking alone when they are re-powered up, mine does anyway, all I can think is put the doors in the state you want locked/unlocked, disconnect the battery then reconnect it and see if that resets them to what you want?
Old Sep 25, 2010 | 10:00 AM
Try disconnecting the battery but when reconnecting(after leaving 5 mins) make sure all the doors are shut and hold down/disconnect the bonnet switch, make sure also the interior light is not turned on.
Old Sep 25, 2010 | 11:32 AM
TrevCos's Avatar
TrevCos
I had a similar problem on my S1, and it was actually the central locking interface that was the problem. I could be going up the dual carriageway and it was locking and unlocking the doors randomly. Seemed to be worse in wet or damp weather.
Old Sep 26, 2010 | 10:51 PM
akito-man's Avatar
akito-man
mental,still doing it,press to unlock the doors,it does,but imediately locks them before you get a chance to get in.shoulda bought a frog,or a newt!
Old Sep 27, 2010 | 11:55 AM
You may have a stuck door lock or linkage if stuck in the lock mode it will unlock then immediately relock once unlock pulse has finished.
Old Sep 27, 2010 | 12:13 PM
london_chris's Avatar
london_chris
that sounds like one of the central locking solenoids bouncing to be fair, not an alarm fault,
if the alarm wasnt working it wouldnt lock and unlock the doors,
sounds like one of your cars locking solenoids is up the swanny.
Old Sep 27, 2010 | 12:29 PM
martysmartie's Avatar
martysmartie
What he ^^ said, usually one of the master linkages is sticky so one motor opens but the other doesn't the pulse times out and as the other lock is neither open or closed locks the doors again, lubricating the linkage will sort this problem.
Martin
Old Sep 30, 2010 | 05:52 PM
akito-man's Avatar
akito-man
will try and lube.see how i get on(oo-er)! cheers!
Old Oct 16, 2010 | 03:50 PM
akito-man's Avatar
akito-man
yes tab,u were rite,my manky door slave solenoid has goosed up,so im in da process of finding a replacement,wish me luck.needing one soon.
Old Oct 16, 2010 | 04:40 PM
BM08's Avatar
BM08
Yeah so dont blame the Toad! millions big them up, including myself
Old Oct 16, 2010 | 09:17 PM
akito-man's Avatar
akito-man
oh for sure,the alarms spankin.just couldnt figure the wonky thing out,but it makes sense .
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
Rammer46
Sep 18, 2015 08:31 AM
Iain Mac
Sep 13, 2015 09:16 PM
jdsjojo
Aug 26, 2015 10:09 PM
