golf gTI timing belt?
Old Sep 23, 2010 | 04:03 PM
gingeRS's Avatar
gingeRS
Default golf gTI timing belt?
Golf mk4 GTI (1.8T)…..been offered one for £2300 on the agreement that I help fix another car
Its done 70k and the timing belt hasn’t been done?
Dealbreaker?
Old Sep 23, 2010 | 04:29 PM
stevos's Avatar
stevos
Had an octavia 1.8t and it was a very good car. timing belt was a peice of piss just bought the kit for £90.Would recommend if you went for it to also change the water pump as the impelors are plastic and break up.When i done mine it was in four bits. good engines though
Old Sep 23, 2010 | 04:41 PM
gingeRS's Avatar
gingeRS
i'm fairly good mechanically just dont have access to lifts just ramps and basic tools, have heard its worth doing the waterpump at the same time....looks like i'm gonna go for the car, seeing another one saturday to get some contrast on this one, decide if its a good idea!
Old Sep 23, 2010 | 04:45 PM
stevos's Avatar
stevos
Your more than capable of doing it then i would say. i just jacked up the drivers side and took the wheel of and had plenty of access although this was on an octavia there may have been more room but having seen a timing belt done on my 172 clio nothing is tighter than that.
Good thing to do is to clean out the throttle body as well as these can coak up afer a while just clean with a bit of break cleaner.
Old Sep 23, 2010 | 07:17 PM
jamie's's Avatar
jamie's
easy enough to do,
the hardest bit is trying to get the alloy mount out the bay,
its akward, if it aint been done its defo got to be done asap
Old Sep 23, 2010 | 07:22 PM
phil_rs's Avatar
phil_rs
yam yammer
60k or 6 years is the interval IIRC
Old Sep 23, 2010 | 07:30 PM
rs-tuner's Avatar
rs-tuner
No it's 4 years or 115k
Old Sep 23, 2010 | 08:46 PM
DAN P's Avatar
DAN P
for the s and t reg book says 120 k or 10 years lol after that it was 80 k
RUBY123
Oct 22, 2023 12:04 PM
paceo
Feb 3, 2016 10:31 AM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
taylora1409
Aug 12, 2015 12:06 PM
