Likely culprits? n/s steering knock...
Old Sep 21, 2010 | 04:20 PM
Nero's Avatar
Nero
Default Likely culprits? n/s steering knock...
I don't have any play through my steering wheel (to speak of), but I get a slight 'clunk' over uneven roads/ potholes/ etc. from my n/s suspension (I think).
Any suggestions as to what it might be and advice on how to check for each symptom?
Many thanks,
Ben
Old Sep 21, 2010 | 06:07 PM
Alvyn's Avatar
Alvyn
lower ball joint, knackered shock possibly?? main question though what car is it?
Old Sep 21, 2010 | 06:48 PM
Nero's Avatar
Nero
Sorry, it's a Mk1 Focus 1.8 Zetec.
Old Sep 21, 2010 | 08:20 PM
ECOS95's Avatar
ECOS95
Probably the bottom arm, easy enough to check with a long bar with the car in the air & wheel off.
Old Sep 21, 2010 | 08:22 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
wishbones or track rods even replce the anti rool bushes that solved my ecos
Old Sep 21, 2010 | 10:01 PM
Alvyn's Avatar
Alvyn
was only kidding with ya could well be the wish bones as said above but if it's knackered your best changing the pair!
Old Sep 21, 2010 | 10:11 PM
benjaminsarmy
just asked my mechanic he said can poss be top mount on the strut (suspention)
Old Sep 21, 2010 | 10:36 PM
phil_focus's Avatar
phil_focus
my focus had this especaly when turning left but always on uneven ground and it was the lower arm ball joint. i think you can get replacement ball joints but you have to carefully cut the old ones off as they're rivited on with those big fuckers.
defo replace both sides though to keep geometry even. i just replaced both wishbones with new ford ones as my car had done over 100k so thought new bushes would be good too.
EDIT: get the tracking done after too. tell the garage that you;ve changed the wishbones and you'll get a second check and minor adjust free 2 weeks later 8)
155lee
Sep 6, 2016 11:10 AM
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
