400+bhp bits(T38/55s/L8) ALL SOLD
I still have the above for sale due to a new T4 setup..
SOLD
UT T38..
.63 exhaust housing,.6 AR Compressor wheel,360 thrust bearing and step gap oil seal.
Has had a new wastegate arm fitted and a full health check by CR turbos approx 600 miles ago. Unit has covered about 1800 miles in total
No smoke at all
£600 + p&p
Siemens 3102 (55lb) Injectors.. Very low mileage purchased from NMS.
£200+p&p
Level 8 ECU with Pectel Babyboard.
£200+P&P
MSD Chip for all of the above:
£150+P&P
Will do the ECU and chip for £300 posted
Or the whole lot for £1050 posted
Unleash the potential in your cosworth!
Thanks,
Luke.
SOLD
UT T38..
No smoke at all
£600 + p&p
£200+p&p
£200+P&P
£150+P&P
Thanks,
Luke.
Hi Kelv,
I'm in west berks mate Newbury area
if you were serious about it I'd be happy to come east on the M4 and meet you somewhere to have a butchers
Pete,
thanks mate you diamond
luke.
Pete,
luke.
bit of a tech question then: these MSD chips, can these then be re-mapped in a live map sesh by MSD? or would i need to buy a fresh one for them to map?
I'm temped for this turbo and chip but scared i may blow the shiz out my gearbox
I ask because i've ran over 420bhp/380ft/lb fine on my 2wd box and others are running more, again, depends how it's driven i guess..
Go on, go for it......
Is it 2wd or 4wd your car Fella??
4x4
i'm living on borrowed time already
4x4
cossie09
Sep 14, 2015 04:21 PM
