tile adhesive setting time?
Old Sep 20, 2010 | 11:53 AM
john_p_b's Avatar
john_p_b
Default tile adhesive setting time?
gotta be someone on here in the know.
been doing my bathroom for a few weeks now, finished tiling on thursday night and the plumber came in saturday to fit everything up. i got home saturday night to find broken tiles behind the shower screen he'd fitted. rang him up and he's been back today to put right but he's rang me and said the reason the tiles are breaking is because they aren't set yet. they'd had a good 36+ hours before he got there and started drilling them so surely in that time they should be set?
can anyone enlighten me?
Old Sep 20, 2010 | 05:29 PM
dingla rs's Avatar
dingla rs
did you cover the hole back tile so it was all stuck to wall as if there a gap easy to break when drilling ,use a tile drill works every time even if tiles dot an dabd
probly put too bigger screw in an cracked it
Old Sep 20, 2010 | 05:55 PM
james kiely's Avatar
james kiely
did he try use a masonary bit,tiles should have set in 36 hrs
Old Sep 20, 2010 | 06:06 PM
Chris84's Avatar
Chris84
I just finished my bathroom 4 days ago. All tiled i put my screen up and blind the day after no probs was dry set just gotta be careful when drilling though tiles i did a pilot hole first so it dont lift the tile up or crack it
Old Sep 20, 2010 | 06:14 PM
s1cab's Avatar
s1cab
i do tiling basically everyday they are always fine to drill into the next day 24hrs they should be completly dry. as for drilling into tiles you can use proper tile drill bits or masonary bits into the cheaper tiles not granite,porcelin,marble etc. ask the plumber how he drilled the holes as in was the drill on hammer ? you never know...
Old Sep 20, 2010 | 07:04 PM
morcheen's Avatar
morcheen
depends how heavy handed the plumber is,never had a problem drilling the next day,off hammer of course
Old Sep 20, 2010 | 07:36 PM
St3V3_C's Avatar
St3V3_C
As above, should be no problem using proper tile drill bits NOT on hammer.
Old Sep 20, 2010 | 08:00 PM
morcheen's Avatar
morcheen
always used normal masonary bits no problem
Old Sep 20, 2010 | 08:04 PM
St3V3_C's Avatar
St3V3_C
Yea, so much easier than the bits I've posted above
These bits don't:
Skate around getting started
Crack tiles - no matter how close to the edge
Need a hammer drill.
No brainer
Old Sep 20, 2010 | 08:14 PM
morcheen's Avatar
morcheen
depends how good the tradesman is
Old Sep 20, 2010 | 08:19 PM
St3V3_C's Avatar
St3V3_C
Depends if you are asked to drill into someone elses tiling
Old Sep 20, 2010 | 08:36 PM
s1cab's Avatar
s1cab
i always use bosch drill bits. http://www.screwfix.com/prods/65876/...14%20x%20250mm these go through almost anything. since i've used these drill bits i have never cracked a tile...... yet
Old Sep 20, 2010 | 08:48 PM
St3V3_C's Avatar
St3V3_C
I was unsure about these - but liked the idea. It's NOT hammer for tiles right?
Old Sep 20, 2010 | 08:55 PM
s1cab's Avatar
s1cab
no its not hammer that will crack a tile 100%. but since ive used these drill bits they're all i use now for everything !
Old Sep 20, 2010 | 08:56 PM
St3V3_C's Avatar
St3V3_C
OK, I'm buying some
Old Sep 20, 2010 | 09:04 PM
boothy's Avatar
boothy
These bits don't:
No brainer
Spot on mate
Old Sep 20, 2010 | 11:25 PM
mrjenrst's Avatar
mrjenrst
i had to drill through tile's last week in the shower, used a 4mm hss bit as it was all i had as a pilot then masonary to size. Did it better than i thought tbh
Old Sep 21, 2010 | 12:07 AM
vaughant's Avatar
vaughant
Those Bosch drills are amazing.used them for everything in my house with no bother.masonry drills were fine for my tiles in the bathroom but they were travertine.
I put them on the floor as well and specifically told the missus NOT to walk on them until their set properly the next day.what does she do?walk straight over them and crack three just to close the window ARGHHHHH!!!
Had to redo the floor then so I put them on tile cement then instead,no probs since.
Old Sep 21, 2010 | 06:18 AM
s1cab's Avatar
s1cab
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
