1987 Ford Sierra RS Cosworth. From the begining to the begining.. Many pictures!
Hi,
In 2005 i bought my cossie, imported from Italy same year.
Engine spec 2005 : Unknown 270 chip and homemade exhaust from org. downpipe.
Suspension 2005: KYB shocks and unknown springs.
Wheels : 15" OZ racing F1 with 205-50-15 Goodyear Ealges F1.
Other: 18mm spacer.
In this tread I'll show the history of my car from i bought it. Now it's parked in the garage for a total repair for the next 3 years. If every thing goes how I've planed it, it will be finish when the season of 2013 begins, with 110% finish over all!
I will add pics now and then from this 5 years, step by step, and hope you'll like it, even if it not so extreme so the others threads
I'll start with the sales pics.
2005
Other: 18mm spacer.
2005
I then got it home, and some changes where done the same day. For information, all the lights is now original again
New blinkers and taillights, all white.
New polys. At first only in front, but later I changed at the rear as well..
New Turbogroove brakedisc and Redstuff brakepads.
Compomotive MO6 was bought
8x17 ET35.
And then new paint where the next thing to do..
http://i48.photobucket.com/albums/f2...Burning004.jpg
2007 is started!
To my big suprise, it's wasn't no 7,5" diff, it's was an 7" diff with small axels and small brakedisc. Probably from ĺ sierra 2,9 or something simular. Not good!
But, I still drive on it, so it have been holding on..hehe..
New polys and Eibach springs. The Eibach where mounted with adjustebal Koni.
Then I went for a dyno pull .. Spec where now 3" blueflame and still the unknown chip and pressure 0,8bar.
223,9 whp @ 0,8bar
Then, before a weekend @ Gatebil Rudskogen 2007 i made som stereo. To day, this is all taken out and I just have an cd-player, that's all. But still, here is it.
Interior
The blueflame tip is a littlebit to long.. Will fix that in te coming years now.. The tip is btw 3,5"
Because of sky high taxes on imported cars, I had to wait sometime to get it registerd, but late in 2007 I hade enough money and took the car to a control, and paid. In Ł it had been about Ł5000, only for the reg. plates. FUCK THE TAXES!
And that was the last of 2007... 2008 is coming soon.
223,9 whp @ 0,8bar
Interior
New timebelt and grp.A headgasget etc...
And that's all that happend in 2008. Because of MUCH work, and no spare time, I didn't use it more than a couple of days the whole year..
2009
Big plan to rebuild the engine. But again, no spare time, and everything I planed didn't work out.. But I did start......
and there it was, with out engine for 3-4 months. Nothing happend!
In the begining of the summer some parts came a long, and it was time to put the engine back and get it out on the road...
Airtech RS500 vs original!
New Bosch 044 pump and new filter.
And once again, off to Gatebil! Have been at Gatebil summer event 8 years. Only once with out my car, and that where back in 2008 i'll think.
New daily driver
It's the cheaper version without, but have electric windows and central locking (or what it's called?) Saves some kg
2010
Some new parts this year.. This is the only summer I have used the car for real, and it felt good!!
To bad it's 3 years of waiting for driving it again...
Re-painted the wheels, and fitted new ToyoProxes
Very pleased with the new look on the wheels!
On the dyno again!
Spec this time:
Custom chip
Airtech intercooler
Garrett -34 actuator
Standar 2wd turbo
3" blueflame
3bar map
Bosch 803's
Pressure; peaks @1,7bar, steady @1,5bar
DYNO RESULT: 306,7hp @ wheels, and 398NM @ wheels!
And here is some show of pics
Comments are allways good people!
On the dyno again!
Spec this time:
Custom chip
Airtech intercooler
Standar 2wd turbo
3" blueflame
3bar map
Bosch 803's
