idle dropping
Old Sep 20, 2010 | 07:23 AM
davecosworth's Avatar
davecosworth
IM BACK
Default idle dropping
my idle is dropping off then correcting its self then runs fine for a minute or 2 then it drops off again its like the car wants to stall then the iscv is correcting it am going to check the tps later have checked the iscv and thats fine, any suggestions would be great as the car has never suffered from idle problems b4 its had new leads plugs cap rotor arm etc
Old Sep 20, 2010 | 10:21 AM
martysmartie's Avatar
martysmartie
What is the base idle? If it's to low the ISCV will bring it up until it drops again and then do the same thing, although this shouldn't have changed unless it's been touched, otherwise as you say check TPS.
Martin
Old Sep 20, 2010 | 10:24 AM
davecosworth
IM BACK
no it hadn't been touched mate checked it the other day and all good thinking it must be the tps will check it tonight and see what i get
Old Sep 20, 2010 | 10:36 AM
martysmartie
In that case almost defo TPS.
Martin
Old Sep 20, 2010 | 11:53 AM
davecosworth
IM BACK
do you no any places that i can get a new one from burtons wants £90 plus postage or is that about right
Old Sep 20, 2010 | 04:11 PM
martysmartie
Yes there not cheap! The old one probably just needs adjusting, you can measure the output quite easily, the common problem with this is they have a wear spot this usually shows itself in slow moving traffic I.E at partial throttle.
But they are adjustable as well.
At WOT the output should be 5V
Martin
Old Sep 20, 2010 | 09:20 PM
davecosworth
IM BACK
ok cant get a decent piont when adjusted i get a load of revs or the idle dropping i just unplugs the iscv utill i can order the the new tps as with the iscv removed it idles at base idle and doesn't drop untill vans cut in but a bit of a flat spot as you go to pull away i run a level 8 so its a pfo9
Old Sep 21, 2010 | 10:16 AM
As it's a L8 look on ebay under DUCATI, 100% EXACT SAME SENSOR right down to the part number, from about £35.
I'd be checking the idle CO if I were you as well.
Old Sep 21, 2010 | 10:57 AM
davecosworth
IM BACK
i just picked it up from the enhanced performance and it was all map and running fine untill the next day when the thing stated to play up thanks for the advise
fordrallycar
Sep 30, 2015 07:57 PM
Marv888
Sep 26, 2015 03:44 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
