little help please. in a dilemma
THIS IS NOT A FOR SALE THREAD SO PLEASE DO NOT REMOVE
ok well i decided a couple of weeks ago to break my dream saph as i have the chance to buy a 500. this is the only car i said i would break my car for.
a chap phoned this evening saying he was interested in the shell so i need you to help me price the rest of the bits to see if i can get enough out of it .
ALL PARTS ARE LESS THAN 1000 MILES OLD SO ARE AS NEW
rs 4 spoke wheel mint
3 racetech guages in plate for centre vents with braided lines
oil pres/temp boost pres and fuel pres.
60mm greddy egt guage 1200 degrees c. comes set in carbon for right hand vent next the door. comes with all hardware
innovate afr guage . and air intake temp guage in panel to go where clock is. comes with all hardware.
hks turbo timer with harness
4x 83lb black siemen from msd
3 bar map
044 pump with filter in cradle
full aeroquip lines from pump to filter, filter to rail, rail to fpr and fpr to tank. all genuine aeroquip lines and fittings
billet fuel rail in silver from mike rainbird
aeromotive fpr with guage mounted on it
spec r header tank with glass, breather and catch tank where the airbox goes and swirl pot ,comes with braided pipes and hose finishers, all freshly coated in satin black
full set of rosse motorsport silicone hoses in black
radtec rad with spal slimline fan kit attached
radtec rs500 cooler
k&n group a filter
2.25 ltr plumbeb in fire extinguisher with all pull cables pipes and fitting .
mounted in boot .also comes with custom strutbrace to hide pipes and mount nozzles
tilton racing bias valve
300 mm rear brake conversion with hispec billet caliper in red . no name machine on them and i have ap stickers on them. with ferodo ds 2500 pads. absolutely zero wear. uses standard handbrake cables
front 2wd ap racing cp5555 in red with 356x36 discs which are wider than normal ap kit . come with ds2500 pads and will fit behind 17 inch rl7,s. absolutely no wear. come with braided lines
full braided brake lines from pump to bias valve and from valve to rear brakes . valve mounted between coil and header tank.
2wd koni,s and ahmed bayjoo springs
front compression strut kit with all hardware and bladed arb with spherical drop links.
adjustable 2wd tca,s
rear zoo 6 degree beam in silver
rear 2wd diff fitted with quaife atb by cts
poly diff mount from mike
harvey gibbs spec universal turbos t38 done nothing
piper cam pulleys in red and black
cam cover with in red with carbon centre
coilpack coil with custom magnecor leads to sit bhind battery on inner wing
msd l8 ecu . live map for 400 bhp , closed loop, coilpack, anti lag, launch control etc
ryan 2wd loom with extra coilpack loom and closed loop loom built in
msd air injector kit with loom
probably forgot some stuff but can you please help me price this stuff in sterling. dont for get that it has done less than 1000 miles so all is mint
thanks gary
3 bar map
radtec rs500 cooler
k&n group a filter
thanks gary
rs 4 spoke wheel mint-100
oil pres/temp boost pres and fuel pres.-90
hks turbo timer with harness- not alot because not expensive new
3 bar map-30
044 pump with filter in cradle -130
spec r header tank with glass, breather and catch tank where the airbox goes and swirl pot ,comes with braided pipes and hose finishers, all freshly coated in satin black - 100
full set of rosse motorsport silicone hoses in black- 140 or so
radtec rs500 cooler- 130
k&n group a filter 30
300 mm rear brake conversion with hispec billet caliper in red . no name machine on them and i have ap stickers on them. with ferodo ds 2500 pads. absolutely zero wear. uses standard handbrake cables- 320
2wd koni,s and ahmed bayjoo springs 400
adjustable 2wd tca,s 100
poly diff mount from mike 100
piper cam pulleys in red and black 80
don't shoot me or anything just my opinion them prices
3 bar map-30
rs 4 spoke wheel mint 200
oil pres/temp boost pres and fuel pres.150
60mm greddy egt guage 1200 degrees c. comes set in carbon for right hand vent next the door. comes with all hardware 150
innovate afr guage . and air intake temp guage in panel to go where clock is. comes with all hardware.150
hks turbo timer with harness 80
4x 83lb black siemen from msd 150
3 bar map 50
044 pump with filter in cradle 150
full aeroquip lines from pump to filter, filter to rail, rail to fpr and fpr to tank. all genuine aeroquip lines and fittings 200
billet fuel rail in silver from mike rainbird 75
spec r header tank with glass, breather and catch tank where the airbox goes and swirl pot ,comes with braided pipes and hose finishers, all freshly coated in satin black 300
pm me a price please
radtec rad with spal slimline fan kit attached 150
radtec rs500 cooler 150
k&n group a filter 75
mounted in boot .also comes with custom strutbrace to hide pipes and mount nozzles 120
tilton racing bias valve 75
300 mm rear brake conversion with hispec billet caliper in red . no name machine on them and i have ap stickers on them. with ferodo ds 2500 pads. absolutely zero wear. uses standard handbrake cables 350
front 2wd ap racing cp5555 in red with 356x36 discs which are wider than normal ap kit . come with ds2500 pads and will fit behind 17 inch rl7,s. absolutely no wear. come with braided lines 750
front compression strut kit with all hardware and bladed arb with spherical drop links. 300
rear zoo 6 degree beam in silver 600
rear 2wd diff fitted with quaife atb by cts 700
poly diff mount from mike 85
harvey gibbs spec universal turbos t38 done nothing 500
piper cam pulleys in red and black 125
cam cover with in red with carbon centre 150
coilpack coil with custom magnecor leads to sit bhind battery on inner wing 150
msd l8 ecu . live map for 400 bhp , closed loop, coilpack, anti lag, launch control etc 500
300
msd air injector kit with loom 125
gave it a go gary ,but im not too sure on some prices
if only you were breaking it sooner i have brought pallets of stuff over from the uk in the last 6 months to rebuild my 2wd saff.
3 bar map 50
pm me a price pleaseradtec rad with spal slimline fan kit attached 150
300
3 bar map 50
300
3 bar map 50
300
hks turbo timer with harness 80 their only 70 to 80 new m8
well its still not deffo james but yeah it would have worked well for both of us. while your on do you know anyone for a 1500 mile engine?
your prices seem to be in line with what i was thinking apart from front brakes . i paid over 800 sterling for front calipers alone. must look for receipt for rest of kit
damien . i appreciate your help but Ł100 for spec r stuff?
i have a receipt for Ł840 but forgot that includes power steering bottle
its frightening to go through old receipts tbh . i think ill need a stiff drink soon
just found receipt from mike r... front discs ,bells ,brackets and pads Ł1050 plus Ł800 for calipers so i would be hoping to get a little more than 750
your probably right gary ,closer to 1000 sounds about right .what kind of price you getting on the shell mate pm me if it suits .
pics speak a thousand words gary ,and the better the pic the better the price you will get mate within reason
il take the grp A air filter/3 bar map i can call down to your's gary to lift them?
my brother might need some things for the new engine he's getting built
have you got many 4x4 boxes?
andy . have one 4x4 box going cheap. tell him not to bother getting engine built. he can buy mine complete . 400 bhp
shell is not sold yet so send him on to me. ill let you know once its broken for the bits you want
Hi,
first dibs on the zoo rear beam when you break it.
you got any pics of this fitted? as i have heard rumors of bad welding on some of them.
i didnt know you could still get Zoo beams so is this also less than 1000 miles
Thanks Adam
Thanks Adam
this beam was bought 4 years ago or so. less than 1000 miles .someone else has first dibs via pm but you will get second.
welds are by no means the prettiest ive seen but are plenty strong enough. if they werent i would have had them redone.
one of the best mods ive done to this car. 4x4 traction in a 2wd when combined with the quaife
1st dibs on the 2.25 ltr plumbeb in fire extinguisher with all pull cables pipes and fitting .
Dont forget!!LOL
Dont forget!!LOL
lads. i will know thursday evening if this is deffo getting broke. if it is ,people who have first dibs on things will get them .
please be patient as i will know thursday if shell is going
thanks
gary
thanks
gary
i thought i was going to be the first one asking as well but owell not quick enough
adam
lads a new post will be up thursday or friday with prices etc.
to see the car in its present state see my for car for sale ad on the rsoc.
dont know how to post a link.
kev the ecu has wasted spark . live map for standard engine , harvey t38, closed loop , lc, als, air injector , runs 2 bar . runs flawless and has very steady afr right up the range
350 then
