sierra cosworth brake lights
Old Sep 18, 2010 | 06:03 PM
stumpy's Avatar
stumpy
Default sierra cosworth brake lights
my car seems to have no brake lights both bulbs are good and all fuses under the bonnet are ok. Also have checked the switch with a meter and this working fine as well.
Is there any relay for them if so which one is it? Also is there another fuse for them at all maybe in the passenger foot well?
Any advice would be great
Thanks
Old Sep 19, 2010 | 11:12 AM
Put the ignition on and check that one of the two pins at the switch plug is live, if it is then either the switch is duff, or there is a break between plug and rear lights, there is no relay for the brake lights.
Using a metre is ok but this will miss things ie it can easily read ok on a multi metre esp a digi one, but not have suffecient conductivity to pass current under load, brake lights are going to use roughly 3.5 amps, a multi metre passes a huge amount less.
If no live present with ignition on then check fuse 21 very carefully pull it out, due to age and the use of aluminum for the blades of the fuses these corrode, often just a clean up with a bit of emery will sort things, of course one of the terminals the fuse goes into will be live with ignition on.
Old Sep 20, 2010 | 09:02 PM
stumpy's Avatar
stumpy
All fixed thanks for the advice.
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
