crap ford KA fuel consumption
Old Sep 18, 2010 | 04:00 PM
mrviper's Avatar
mrviper
Default crap ford KA fuel consumption
my dads 53reg 1.3 colection ka is gutless and feels like some one has shoved a banana up the exhaust
when i borrowed it to do a 175 mile round trip to fetch my gearbox i was having trouble keeping up with traffic at 70mph on the motorway with a slight hill and knocking it down to 4th did nothing!
i left with a full tank and used the minimal amount of throttle to keep up with traffic and it was duel carige way/motorway for most of the trip and when i got back it took £35 to fill it up again
i bunged the stats in to a mpg calculator and got this:
Fuel Cost 114p a litre
Total spend: £35
Distance 175 miles
Your real-world MPG average is 25.91, covering 175 miles using 6.75 gallons of fuel.
thats fooking shocking
is this normal ? or is there a comon problem that needs fixing?
Old Sep 18, 2010 | 04:54 PM
billybigspuds's Avatar
billybigspuds
blocked cat? tappets too tight?
Old Sep 18, 2010 | 04:57 PM
vaughant's Avatar
vaughant
Deffo blocked cat,had the same problem on my mk7 escort 1.4,eventually it wouldn't even go uphill!!!70 absolute top end speed.I ripped the cat off and it was doing 70 in third,had 110 down the motorway as well,it was like a new car.went from 50 miles to a tenner to nearly 90!!!
Old Sep 18, 2010 | 05:40 PM
mrviper's Avatar
mrviper
blocked cat dont sound cheap! time to look on euro parts
its only got 32k on the clock aswell!
i just checked and it is 307 quid for a fookin cat
http://www.eurocarparts.com/ecp/c/Fo...84095c9de&EPCT
maybe il decat it and leave a bottle of vodaka on the seat for the mot tester *cough*
Old Sep 18, 2010 | 09:03 PM
vaughant's Avatar
vaughant
Pretty sure you could get an universal cat for about £90?I decatted mine but it was an old girl on an r plate and I never re moted it!!
I'd think second hand no more than about £50?you could remove the cat from the system and have a look inside.normally,if it's blocked,when you give it a shake you should hear it rattling about a bit,or even see big bits of it moving around in the cat.the car will start to sound like someones put their hand on the tailpipe to check for leaks.
Old Sep 18, 2010 | 10:35 PM
ASHCOSSIE's Avatar
ASHCOSSIE
my nans daewoo nexia 1,6 auto is worse than the cossie on a run, u got nothing to worrie about lol
Old Sep 19, 2010 | 09:22 AM
billybigspuds
ive got one from a fiesta at work, im sure there pretty much the same, or i might be talking complete bollox as i sware im still pissed from last night
Old Sep 19, 2010 | 09:41 AM
silky16v's Avatar
silky16v
Get on That!
is the engine a 1.3 Duratec on Endura-E?
If it a duratec the CAT is part of the Exhaust Manifold
it's actually cheaper to buy a www.stevewyndhamracing.commanifold and a sports cat, there next to nothing in the way of tuning in this country for the Duratec.
Old Sep 19, 2010 | 10:01 AM
billybigspuds
as i say ive got one at work that im pretty sure will fit, do a bit of googling and if it does ill work something out for ya, i will have to check moro that its intact tho
Old Sep 19, 2010 | 11:55 AM
Recently replaced a cat on a mk1 mondy around £70 from exhausts unlimited in Norwich, Norfolk, might be worth a try, though I'd be looking at the lambda as well.
JoeyBoyden
Aug 18, 2015 10:52 PM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
