General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Yea the DW10 engine is common for fly wheels to go.The engine will be out of balance or a clatter coming from the bell housing as you rev the engine from idle.If you need a fly wheel make sure you buy it as a set, fly wheel,clutch,pressure plate cause they have modified the pressure plate.Its around 900 Nm stronger.If you fit the old pressure plate it will slip. Unfortunately I learned the hard way and bough a clutch and plate from a auto factors and a genuine fly wheel.
