s2,automatic choke sticking on help please!!!
Old Sep 17, 2010 | 05:45 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default s2,automatic choke sticking on help please!!!
as above is there anyway i can disconnect the automatic choke on my s2 it keeps stayin on,then for a split second its as if its going to shut off and then picks back up and idles at just under 2k rpm.i dont even know which plug it would that associated with it
Old Sep 17, 2010 | 07:38 PM
JamesyRS's Avatar
JamesyRS
choke? do you mean cold start valve? If so then its the blue plug I think on back of manifold right in middle. If you follow fuel line from metering unit to manifold you will find it hope this helps
Old Sep 17, 2010 | 07:58 PM
rickbartlett
G911 TTA
thats the one mate,cheers top man,so unpluggin this shud drop the revs from cold?
Old Sep 17, 2010 | 10:27 PM
JamesyRS's Avatar
JamesyRS
mines was unplugged for some reason and it stayed at normal revs mate
Old Sep 18, 2010 | 07:47 AM
rickbartlett
G911 TTA
Cheers mate,i will try it later
Old Sep 18, 2010 | 09:34 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
rick, most people just unplug the cold start anyway as they are useless and cause problems with starting
Old Sep 18, 2010 | 11:22 AM
rickbartlett
G911 TTA
cheers milesy,ive never had any trouble b4 with all my other rs turbos lol,
it starts first flick of the key and then idles at about 1k rpm ,then after a few seconds it rises to around 2k rpm, and stays at those revs, and sometimes its as if it is about to shut off and then comes back on again lol
Old Sep 18, 2010 | 11:51 AM
milesy23rst
PUG 306 GTI-6
Just unplug it m8 that should cure it, new rs going ok??
Old Sep 18, 2010 | 02:25 PM
If you take the valve off, then freeze overnight in the freezer then take out and drop into some boiling water this often springs them back into life, what I did to my 4i one worked perfect after that.
Old Sep 19, 2010 | 09:33 AM
rickbartlett
G911 TTA
cheers tabetha i will try that,thanks as the cold start will b handy to have now the cold mornings are comin
boeb
Jan 9, 2020 05:11 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
