cossie oil leak.
Old Sep 17, 2010 | 03:44 PM
muffster's Avatar
muffster
Default cossie oil leak.
Hi folks,
ive got and oil leak on my 2wd cossie but i cant tell where its coming from. I recently changed the oil feed to the turbo and the oil pressure switch but they have been fine, no leaks since being changed. Ive got oil patches on the garage floor , ive jacked the car up and got under it when its running but cant find where its coming from. There is a lot of oil around the bottom end of the engine and its seems to have sprayed on to the starter motor and even on the underside of the distributor leads!!
Are there any other usual suspects which could be leaking? And where abouts is the breather?
Cheers,
Muffster.
Old Sep 17, 2010 | 03:53 PM
martysmartie's Avatar
martysmartie
Check the cam seals at the front and also the cam cover gasket, the standard kidney box affair is located beneath the inlet manifold.
Martin
Old Sep 17, 2010 | 04:02 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Rocker cover always seems to be the first to let go on mine, oil from the breathers too
yes this kidney box they speak of, is it common for this to be removed?
Old Sep 17, 2010 | 04:09 PM
martysmartie
Depends on the type of aftermarket breather fitted really.
Martin
Old Sep 18, 2010 | 12:39 PM
Alvyn's Avatar
Alvyn
IF you have alot of oil underneath your best bet would be to go and get it steamed off so you can have a good look! also if the starters covered you sure the new oil switch you fitted hasn't failed as they are known weak point!
Old Sep 19, 2010 | 11:21 AM
I'd do as above and steam clean it off first.
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
krypton
Sep 23, 2015 07:29 PM
Chopshop85
Sep 18, 2015 06:13 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
talon1
Sep 15, 2015 10:27 AM
