2wd Springs - what ones?
Hello all, i have a 2wd saph with 18" wheels with Koni shocks but have no idea what the springs are, the car sits too low at the rear so i was going to change the springs but have no idea what set of springs to buy. Do i go for standard height springs or lowered and is there a particular brand which is best?
any help would be much appreciated.
cheers
Gary
cheers
Gary
hi there
Some people on here rate eibach springs but I'd have to agree wih the above as I also run Ahmed bayjoo springs with konis front and bilsteins rear and the stance and ride is spot on.
You buy them from Martin Hadland
Standard height for me at least that is what I would be getting, the Ahmed springs do lower the car by around 10MM + IIRC.
If looking for std height look at the Avo range although apparently these also lower the car slightly but not so you would notice.
To add Ahmed springs were designed around the Koni shocks so are a good combo
If you do go lower don't do so excessively else this will do more harm than good.
Martin
Martin
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
