Escos parts (last few bits added 16-3-11)
Right,well after my escos project has gone tits and sold my shell ive decided to sell some of the parts that i thought i wouldnt sell! But certain things have happened recently and so have decided that life is too short to hang onto stuff that may/may not ever get used!! Ive got shit loads of odds and sods that are boxed up and havent got pics of yet so mite have it somewhere if you need something i havent listed yet.
Right, here goes :
2 steering racks,1 with pump and hoses attached (for a 2wd saph) + and the other for a escos,both in good condition. offers.
Metal Power steering pipes £20
K+N panel filter for standard escos airbox,vgc £15
Escos heater box £35
Escos lower coolant pipe £25
Pair of Escos bonnet hinges £45
Full set of front and rear wiper arms from escos,in vgc £40
Escos airvents (either ends of the dash) £25
Escos seatbelt kit,includes all bolts/brackets etc £45
Escos ABS controller £30
Escos fuse box (unknown condition as it came with my car) £offers
Standard escos map sensor £15
Escos bonnet latch £10
Escos sunvisors,just need a clean £10
B-pillar seatbelt height adjuster covers £15
Escos mint door handles+screws £50
Escos clutch+brake pedals £40, Accelerator pedal £20
Escos door lock mechanisms £20 per side
Escos throttle cable and bracket £15
Escos seatbelt height adjusters,plastic part slightly faded but work fine £20
Escos/4x4 alloy engine mounts £25
Parcel shelf mounts with alpine speakers £50
Escos rear windows £70
Escos Front grille,mint as you like,£65
Crank pulley,good useable condition but could obviously do with being powder coated, £35
saff/3 door coz crossmember with mounts (not sure on condition of the mounts though) £40
escos oil pump and pickup pipe £50
escos dash+fuse box panel+glovebox etc,has got a few dinks and deep scratches due to me dropping it,but more than usable if you wanted one to be flocked which was what i was going to do eventually! £45
Big turbo inlet manifold with icv etc £90
Gearbox sandwich plate £15
Remote oil housing £20
Dizzy £40
Block oil seal housing £25
Airbag module £20
Inlet (offers)
Escos electric sunroof motor £35
Escos scuttle panel cover,in pretty good condition £20
Right, here goes :
Dizzy £40
Airbag module £20
Inlet (offers)
