Cosworth computer with white screw l1 or l6
Old Sep 12, 2010 | 07:29 PM
rscos2004's Avatar
rscos2004
Default Cosworth computer with white screw l1 or l6
As above ive had this fitted to my 2wd sapp cosworth and not to sure if level 1 or level 6 as ive bought another computer and it is supposed to be l6 and has a different colour screw cheers.
Old Sep 12, 2010 | 07:40 PM
cossiedave's Avatar
cossiedave
L6 OR L8
Old Sep 12, 2010 | 07:53 PM
rscos2004's Avatar
rscos2004
Originally Posted by cossiedave
L6 OR L8
Hi thats confusing as the one i have fitted now has a dark grey screw and is supposed to be l6 i thought the white one was l1.
Old Sep 12, 2010 | 07:56 PM
cossiedave's Avatar
cossiedave
has it got small wings on the side with holes in to screw it in
Old Sep 12, 2010 | 08:08 PM
rscos2004's Avatar
rscos2004
Just looks standard to me both look the same?.
Old Sep 13, 2010 | 07:22 AM
oldford's Avatar
oldford
For pictures of the ecu versions see: http://www.bigturbo.co.uk/main1.htm
Old Sep 13, 2010 | 01:53 PM
The L1 with model number ending in 1 on case has a YELLOW screw, as fitted to 3 door cossie.
The L6 with model number ending in 6, has a white screw, that looks more like silver/grey after a few years, the L1 yellow screw is a very definite yellow.
Definitive way is read the model number on ecu case, assuming no ones changed the pcb!!
Old Sep 13, 2010 | 04:17 PM
rscos2004's Avatar
rscos2004
Thanks to you and tabetha both of them must be l6 its just the other one must be a dirty screw as my original one is white.
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
lukeeboy149
Aug 22, 2015 04:29 PM
john_3.0s
Aug 16, 2015 06:40 PM
Aug 14, 2015 07:29 AM
