Level 8 ECU with Coilpack and Closed Loop Lambda
Old Sep 8, 2010 | 10:13 PM
polly_x's Avatar
polly_x
Default Level 8 ECU with Coilpack and Closed Loop Lambda
For sale is a perfectly working Weber Level 8 ECU with standard babyboard and coilpack drivers fitted.
It also has an 380BHP MSD chip for T34, 55lb Siemans, Coilpack and closed loop Lampda.
I have the Bosch Lambda Sensor and wiring all ready to go to.
Would like to sell as a complete setup (ECU, Chip and Closed Loop Setup) but would split. The Chip and lambda sensor alone from MSD is £400.
Complete setup £500
ECU with Coilpack drivers 275
MSD 380BHP Chip with Closed Loop, Lambda Sensor and wiring 200
Postage is £5
Thanks
Old Sep 9, 2010 | 03:24 PM
Porkie's Avatar
Porkie
This is my ECU.
I also have a almost brand new Garret T34.63 (cost £1100!) and the correct .55lb siemens black injectors to match.
the whole set up did less than 1000miles in my Westfield.
Old Sep 9, 2010 | 05:19 PM
Mr C's Avatar
Mr C
I'm interested in the chip and 55lb injectors too depending on price posted please
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
tib2220
Sep 14, 2015 12:33 PM
