Air con will not switch off properly on 02 focus
Hi,
I have a strange problem with my 02 reg focus.
Basically the air con will not switch off completely. I can hear the cluch switching in when I press the air con button, or if I set the control to windscreen, and it cools down fine.
When I then switch it off, I can hear a faint click of the clutch disengaging, but it carries on blowing out cold air. The bit I find wierd is that it's not actually as cold as it would be if the air con was swiched on, but definitely colder than the outside air temperature.
Thanks for any help you can give.
hi ,iv had a problem with mine even when mine is switch off ,mine still works so i pulled the relay out from under the bonnet but when i put my blower on it turns the air con fan on or the radiator fan on ,you listen to yours to see if that happens to your ,before i pulled the relay out my fuel consumption was crap but now its fine mines 01 diesel
The air con will always be on when the direction is set at windscreen REGARDLESS of AC, but from what your saying you already know about this. It sounds as if the blower is running, have you tried changing to heat to see if this makes a difference?
Martin
Martin
