2.0 pinto, (205 block) complete and can be heard running
I've got a 2.0 pinto fitted with the weber twin choke carb, runs perfectly except for slight valve stem leak causing a little smoke. Unknown mileage, can be heard running, will come with new cambelt, oil filter, stem seals and aux belts, will need fitting by buyer. It's the later electronic dizzy type.
It also comes with:
Four branch manifold
Power steering pump
Alternator
£150
Also have sierra type 9 5speed box in perfect order complete with fork, bellhousing and sierra prop
£100 or £75 if bought with engine
Located in soham cb7
It also comes with:
Power steering pump
Alternator
£150
big_Rad
Sep 15, 2017 09:36 AM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
