Breaking the escort - updated for the remaining items
Almost there!
9x18 Comp MO's/888's, et20 and in black, tyres are 245/40/18's - SOLD
Lower Spoiler and carbon Wolf - £375
Pectel Monitor, fitted to the banana pod gauges and with a brand new larger LCD screen, controls remotley mountable to suit your own desires. Configured for T6 & P8 and covers fuel presure, oil presure, has the exhaust gas thermocouple input and also the D plug to connect up to your laptop - £525
Escort Cosworth front bumper in Mallard green, its mint as its not been used since painting
- £325
Front hubs, front prop and front shafts now sold, but rear shafts and main prop still available
Last edited by Kelv; Oct 23, 2010 at 01:02 AM. Reason: updated for the remaining items!
Almost there!
To late
Coming any moment
coming any moment!
Headlights and mirrors sold, dash pics to follow
Almost there!
Neil, when you heading to Kelv's? If neither of you mind give me a shout and I will pop up the same time if Im available. Can have a look at some bits on the car and see if I need anything
Pics of GrpA ARB front setup - where is it from? Dewitts/TCS/ATM/Nuts Rus? What size bar? Will the crossmember fit a 3dr?
Intertested if it is Dewitts/TCS and tarmac spec (and will fit 3dr).
Almost there!
I don't mate, I removed them years ago and fitted genuine blanks.
If you can bear with me a dew days, I need a few more expensive parts to be allocated before I actually pull the car apart.
Cheers.
Cheers.
Almost there!
they were from Matt Neals old touring car were they not, before i had the centres remade
See you soon
Almost there!
Mark, to much more needed from life than one garage car that will be used maybe once a month on track.
life and its requirements have changed, i dont have the disposable income like i had a few years ago to plough a grand a month into the project and in all honesty im bored with it now.
maybe i out specced myself and set my own goals to high which is partially to blame.
even if i did continue it would still take another 9 months to a year to finish and another 6k, if i downgraded then it would mean the project was pointless as id only end up back where the car started.
it will be replaced with a more modern RS that i can still have the odd trackday in while remaining as a suitable daily car, and also something to cater for the way our lives have moved on and its requirements.
its not a decision thats just happened overnight, but alot of thought of several months has brought me to this equation.
who knows, the shell may even stay in the garage and in a year or so hunt for a tatty old 4x4 saph as a donor to put it back on the road again while keeping everyting else around us that we need.
Indeed ,both Matt and Dan eaves seats from their 2004 Civics .
