noise from my 2wd cossie
Old Aug 30, 2010 | 08:41 AM
m3cosworth's Avatar
m3cosworth
Default noise from my 2wd cossie
ive developed a strange knocking noise from the engine only at a around 3000rpm.
no change to the drive of the car and the oil temp and pressure where fine.
it was due an oil change and it was low on oil. needed a litre to get it to max. but i ended up driving it a little hard yesterday and noise just apperared.
it was sounding tappety but this always happens when the oil is low or dirty.
any ideas guys? how do i diagnose the noise. proper pissed off!
Old Aug 30, 2010 | 09:01 AM
rog's Avatar
rog
If it's knocking then it's knackered I'm afraid. Are you sure it's firing on all cylinders?
Old Aug 30, 2010 | 09:13 AM
m3cosworth's Avatar
m3cosworth
I pulled the ht leads one by one and the knocking was evident throughout. But coming to think of it one of the leads seem to make no difference to the engine note although I will need to do it again to double check. Although I would of expected the car to drive diffrently if it was firing one cylinder less?
Why is it only knocking at a certain rpm??
Old Aug 30, 2010 | 07:18 PM
How many miles has the engine done, how bad is the piston slap when cold, I used to get bad piston slap when warm/hot but due to 200,000 miles.
Old Aug 30, 2010 | 08:14 PM
m3cosworth's Avatar
m3cosworth
cant be 100% sure on the mileage as it an engine conversion car (in a bmw).
no piston slap at all. was very quiet unless it needed an oil change then it would be tappety.
not particularly smokey either.
had the head off 10000 miles ago to de-coke it and all seemed fine. had it on the rollers recently to set it up and all was fine.
Old Aug 30, 2010 | 08:32 PM
LHD220Turbo's Avatar
LHD220Turbo
record a video of it and post it here - by what you are saying it does not look good
is the noise louder when the engine is under load (driving it)?
Old Aug 30, 2010 | 08:48 PM
m3cosworth's Avatar
m3cosworth
ok il get a video up tommarow. just had another look and all cylinders are firing. if i take the leads or injectors off it does effect the idle.
it sounding very much like a diesel car at the mo.
Old Aug 30, 2010 | 09:08 PM
LHD220Turbo
if its really knocking then i'd say the bottom end is in need of a rebuild; dont drive it anymore
Old Aug 30, 2010 | 09:15 PM
m3cosworth's Avatar
m3cosworth
not driving it now. whats my worse and best case scenario? costs wise too.
also am better paying for a rebuild or getting another engine. what would my engibe be worth?
skint at the mo aswell
Old Aug 30, 2010 | 09:21 PM
LHD220Turbo
https://passionford.com/forum/ford-r...ottom-end.html dont know if its sold or not
otherwise it really depends on what's wrong with yours & the crank
you might get away with just a polish and a new set of shells on yours; or your crank could be scrap and you might need new pistons
you'll only know when you pull it apart for inspection
Old Aug 31, 2010 | 05:42 AM
coswurv's Avatar
coswurv
If it was low on oil and you've then gone out and driven it hard i wouldnt mind betting you've starved number 4 big end and made it knock, i think this as ive done it myself once, i also still had good oil pressure after and couldnt understand where the noise was coming from till i pulled it apart, crank grind and new shells etc and all was good, i have now learnt to make sure there always full of oil.
Old Aug 31, 2010 | 08:33 AM
m3cosworth's Avatar
m3cosworth
Sounds about right. What sort of cost would that be mate ?
Wasn't even gona drive it that day and had the oil n filter ready to change. But was pissing it down during the day and by the evening had dried up n my bro just picked up a new car and want a little cruise. Sods law
Old Aug 31, 2010 | 12:47 PM
coswurv's Avatar
coswurv
Well you could do one of two things depending on whether the knock is bottom end, either pull the engine out, remove the sump, pull off the big end caps and see the damage, check the shell size from previous grinds.
Then if it is that whats caused the problem depending on the extent of the damage (spun shell at worse) you could take out the crank and have it ground, new set of mains and big ends, pull the oil pump off for inspection and change if needed, replace all above and refit it to the car, then obviously dont drive it low on oil .
Or secondly pull the motor out and give it a full rebuild as thats what i did, depends on your budget and how paranoid you are in regards to swarf etc floating around after the shell let go, but if doing the above just make sure you give it a good clean out to remove what you can as if its holding good oil pressure still i wouldnt of thought it will be to bad but this is just my advice some people may dissagree.
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
jc1989rs
Sep 5, 2015 08:09 PM
rsturbo27
Sep 5, 2015 05:08 PM
