changing thermotat on 1.8zetec
Old Aug 28, 2010 | 03:47 PM
nralden's Avatar
nralden
Default changing thermotat on 1.8zetec
how do you change the thermostat on on a 1.8 zetec escort si,
does cambelt need removing,
is it hard,
thanks
Old Aug 28, 2010 | 04:17 PM
It's the other end of the engine to the belt, quite easy job, just undo pipes and bolts on stat housing to get at it, make sure to get a new o ring seal, should be with kit, and don't overdo the bolts upon reassembly as housing plastic can break.
Old Aug 28, 2010 | 04:43 PM
RichieST's Avatar
RichieST
When I did mine on my st170 there was no need to remove any pipes. Undo 3 torx screws, whip out old stat, slot new one in, job jobbed. Just make sure you fit the seal on the stat before it goes in, and put a bowl or something underneath the stat housing to collect lost coolant (you will get about half a litre), stick the coolant back in the header tank, 10 minute job!
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
