Solid lifters
Old Aug 21, 2010 | 10:55 PM
JamesyRS's Avatar
JamesyRS
Default Solid lifters
Hey guys just had a rebuild done and thought ad run this by you before phonin company on monday. HAd new head with solid lifters etc but thought the tappet noise was due to this. Took my mate out and he said something wrong there he took rocker cover off to discover one of the rockers was vey loose so he sorted it out took it a spin tappet noise was away came back ended up it had come loose again. The bolt in top seems to go back in and not stay at desired clearance level like the others. is there and easier fix or will I have to wait and phone up on monday, not the kinda person to hassle so rather sort it out than have to tral to and forth. any help will be appreciated!!
Old Aug 21, 2010 | 10:59 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Personally i'd hang fire till Monday and speak to the company who did the work.
If you adjust it yourself and it ultimately causes damage, you'll have no comeback with them. If there's a problem, you need to return it to them for them to rectify it!
Old Aug 22, 2010 | 07:20 AM
I'd also leave alone and let the people who did the work fix the problem.
Prickly_buzz
Dec 7, 2017 09:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
SMILER258
Sep 28, 2015 09:04 AM
